Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
No fast spin
Hotpoint WMS38P,machine works fine until the fast spin is needed, this happens when in full program mode or just the fst spin
  • Hotpoint Master
  • 3,463 Answers
Could be blockage in pump or filter, if there is a blockage then the m/c will not spin with a lot of water in it.
Posted on Dec 13, 2008
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Aquarius wt745 hotpoint machine need to reset the pogram - as machine program not working properly
You have said "Every Program" but I'd like to make sure that's the case. The issue you're describing is highly unlikely to be programming. More likely I would suggest, is that the heater in the machine has failed. As a result, a 60 minute program (Which is planned to take 60 minutes taking into account the average time the water takes to heat up), will run for AGES while the machine waits for the heter to get the water up to temperature, which it can't because the heater is dead. Firstly, test this theory by running a 60 degree wash and feeling the door glass after 20 minutes. It should be HOT, my guess is it will be cold. Also, If I'm right, a cold wash program will run fine (Rinse and spin for instance) As will spin and pump out settings. If this isn't the case, then there is a possibility of a blockage. Though you have said the pump works, I would suggest disconnecting the waste pipe from your drain and putting it into a bucket. Fill the machine and then pump out. The water should FLOOD out VERY fast. If it's slow or a trickle, there is a blockage in the pipe or pump.
Sep 06, 2015 | Hotpoint Washing Machines
My Hotpoint WML560 won't run a full cycle.
Is there a no spin button that has been pressed. Also some delicate cycles have no spin as part of the program.
Dec 14, 2014 | Hotpoint Washing Machines
My hotpoint aquaris machine is not engaging the fast spin function. When it comes to the fast spin in the cycle the machine goes dead. The machine was performing the fast spin until recently however the...
everything you have described points to a blocked pump,worth blowing down the clear pressure pipe from the switch end while your in there to make sure thats clear!
Jan 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
WMA62 aborts all programs after 2 initial spins
if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
