Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer 110 20912 990 will not spin or empty
The washer fills, agitates, (I just changed the dogs) but will not spin or empty
  • ladydiskin Dec 16, 2008
    The door latch has never been disconnected, however I do believe it is the switch inside the door latch. I used a screwdriver and that made the switch work. Now I need to find the correct switch and hopefully replace the old one. thanks for your help
  • Anonymous Mar 21, 2014
    doest not spin but water fill and empty
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like perhaps you dissconnected the door latch assy,and never reconnected??? hte unit will not spin/drain with the door latch not making contact
Posted on Dec 14, 2008
Kenmore 80 series washer fills but does not wash/agitate. will spin and drain when manually turning dial to spin
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
Aug 31, 2009 | Kenmore Washing Machines
WILL NOT AGITATE
Hello, it could be 2 things.
1) You could have worn out dog agitation ears
2) Could need a new transmission
Dog agitation ears would be my first choice and it's pretty easy to fix. Parts will cost you around $10.
Good luck :)
Aug 06, 2009 | Kenmore 27721
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 top load barely agitates....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
564 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
