Question about Canon PowerShot A570 IS Digital Camera
Canon A570 How do you reset the numbering for the pictures in the shoot mode. I emptied the disk but the first picture shows a number of 1029.
  • 3 Answers
Go to the menu function of the camera and go over to the tools at the top of the page, then scroll down to file numbering and move it over to auto reset. that should fix your problem
Posted on Dec 28, 2008
I cannot take photos when i shot with manual mode.The shutter clicks but no picture is actually taken.Darkness.The auto mode works fine.Lens Nikkor Micro AF-S 105mm.Drives me crazy
When you shoot in manual mode, make sure your camera sensor gets enough light. When you shoot inside with dimm light at 1/1000 of a second or faster and a aperture of 8. all pictures will be black.
The best way to learn shooting in manual, is to shoot a picture in the P mode and put the picture on the screen (>) button. then select the info, where you see time, aperture iso and so on. and even better select the histogram. Note the figures in your head (or on paper) and then goto manual and make sure you have almost the same settings. Then shoot en look what the histogram shows. No histogram on the right, means to little light, so lower the shutter speed, open the diaphragm or increase the ISO. No histogram on the left, means to much light, so higher shutter speed, lower ISO or smaler diaphragm (the aperture number must be up. 3,6 is wide open 16 is almost closed.
Mar 14, 2015 | Nikon D7000 Digital Camera
Camera is slow
Use a faster SD card. The write speed number is what you look for. The greater the number the better the card.
Mar 13, 2017 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix S2500 - How do you see how much memory is available after taking photo's
In the shooting and playback modes, if you're in still mode (not video) then in the lower right corner of the screen is a number in square brackets []. This number is a rough estimate of the number of additional pictures you can take before the card fills up. If the card can hold 10,000 or more additional pictures this number will be 9999. In video mode this displays an estimate of the number of additional minutes of video the card can hold.
Mar 16, 2012 | Nikon COOLPIX Cameras
How do i use the burst mode on my nikon d3000? Thank you.
Press the Info button to bring up the Information display. Press the <i> button to place the cursor in the information display. Highlight the current release mode and press OK. Select the Continuous mode and press OK.
This lets you shoot at up to about three frames a second, depending on the shutter speed, noise reduction settings, and autofocus settings. You cannot use this with the flash.
The camera will shoot pictures as long as you hold down the shutter release button (until the buffer and/or memory card fills up). As you shoot, the viewfinder will show rNN where NN is the approximate number of further pictures you can shoot until the buffer fills up. In JPEG mode you should be able to take a hundred pictures before the buffer fills. The number will be smaller in RAW.
In AF-S and AF-A, the camera will not shoot the next picture until focus is acquired, so when shooting moving subjects or panning the camera, you may not get full speed. Even in AF-C, the camera may "hiccup" occasionally.
Mar 15, 2010 | Nikon D5000 Digital Camera
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
I have 00 showing on my lcd
All you have to do is download the pictures on to the PC and then reset the digital camera in mode to CA for (clear all) and it will reset to 20 in the regular mode. Hope this helps. PCS
Jan 01, 2009 | Vivitar MAGNACAM Binocular
Canon EOS 40D shoots on its own.
Sounds like a software issue, try to upgrade or reload the firmware.
I hope it helps :)
Oct 26, 2008 | Canon EOS 40D Digital Camera
Part numbers
I need a new knob for my carrier through the wall air conditioner. I looked into the back of the broken knob and found part number.
0350
1029
stamped inside. I googled it and found the correct knob (saw the picture) at http://bestbuyheatingandairconditioning.com part number KNB3501029.
Not cheap but I found them.
Hope it helps :)
May 02, 2008 | Carrier XHD183D Air Conditioner
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
