Question about Samsung HL-S5687W 56" HDTV
Flashing led lights and no pic or sound on a HL-S5687w samsung tv
I have a samsung hl-s5687w dlp tv that just stopped working ive only had it about 2 years and everything worked fine until one day the tv shut down no pic or sound and all three lights on front are flashing i tried replacing the bulb no luck there, there is a clicking sound when u plug the tv into a power source as though it wants to work but nothing happens. What is the next step i need to try to get this tv working? Please help
  • nanlerob Dec 29, 2008
    I have the same problem. Our SAMSUNG HLS5687WX (model) made a loud pop. The picture went dead & a few seconds later the sound stopped. A crackling was coming out of the tv until we unplugged it. It smelt like plastic burning. This tv is only 14 months old. (The 3 lights started flashing also.)
5 Suggested Answers
SOURCE: my samsung dlp tv hl-s5687w
I had the exact same problem with my TV turning off for no reason. If those two lights are blinking in the front it means your TV thinks the lamp door is open and shuts down. In my case i had to open the door and adjust the spring lever because it was not making good enough contact.
Hope that helps.
Posted on Dec 09, 2008
SAMUEL011
  • 39 Answers
SOURCE: samsung HL-S5687W dlp tv, the picture is darker
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Posted on Jan 05, 2010
Testimonial: "Very prompt solution to my problem, thank you. "
SOURCE: MY SAMSUNG HL-S5687W TURNS OFF BY ITSELF.
From what I have read the most frequent solution to this problem is that the lamp door has become loose and that microswitch on it needs to be reset. Simply loosen the screw to the lamp door and open it a little bit and then close it again making sure that the door is closed tightly and retighten the screw.
Unfortunately, the second most common problem is that the main DMD digital board has developed a problem which is much more expensive to replace.
Raven
Posted on May 10, 2010
ChungYu
  • 76 Answers
SOURCE: How do you operate the
Click tools on the remote, and choose PIP
Posted on Mar 01, 2011
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
My Samsung HL-s5687w turns on only for 3 minutes then turns off standby/temp timer lamp start blinking what dose it mean
Lamp and or ballast are most common BUT did you hear before a high pitched or fan like sound before this happened?
Apr 08, 2012 | Samsung HL-S5687W 56" HDTV
I am having problems with my Samsung HL-S5687W 56 in. HDTV Television It is turning on ok then shuts off after a minute or so.Do you have any recommendations
i have seen before that model have some problems with the lamp door switch. check the back of the tv and make sure that the lamp door is secure otherwise it can be possibly a color wheel or even lamp failure. if you have never replaced the lamp then i would lean more towards that as the root of your problems.
Jan 06, 2011 | Samsung HL-S5687W 56" HDTV
When we turn the TV on, a red light starts to blink but no image or sound is displayed. How can this be fixed?? And What is causing this? my TV model is HL-s5679w
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
http://www.buy.com/prod/samsung-hl-s5687w-hls5687w-bare-lamp-bp96-01472a/q/sellerid/28565179/loc/111/215199305.html
Sep 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung HLS5687W XAA will not stay on
You might have the problem with your standby processor on it, that needs samsung technicians.
May 03, 2017 | Samsung HL-S5087W DLP TV
Samsung HL-S5687W dlp tv, the picture is darker than usual and getting darker by the day
Hi
Regards
Jan 05, 2010 | Samsung HL-S5687W 56" HDTV
Changed my 2year old samsung dlp tv bulb but it is not as bright when i first bought it. Is there anything else I can do to make it brighter?
You need to go into setup and see what TV Mode you are in.
Movie is usually darker then normal. Do you still have the manual?
Apr 29, 2009 | Samsung HL-S5687W 56" HDTV
TV SHUTS OFF
ask for an estimate of cost before the repair is completed,poss. fan or color wheel,power supply.
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5687W 56" HDTV Logo
428 people viewed this question
Jerry Greenberg
Jerry Greenberg
