Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Need screw that holds on the attachments - KitchenAid KP2671 Professional 6 Series Stand Mixer
  • 135 Answers
Go to the website and find the "Parts" area for Kitchenaid mixers. You should be able to download a parts list and drawings for your particular model #. You can order the attachment screw from the same website. Be prepared to wait a month for it to arrive! Whirlpool apparently doesn't consider it's end users important enough to increase processing speed for parts orders. I've been waiting for six weeks for one small part to arrive. I'm still waiting. Good Luck. ricardok45
Posted on Dec 31, 2008
Hamilton beach 950 cover removal
just press in two sides and remove it
Jun 11, 2008 | Hamilton Beach 950 Stand Mixer
My kitchenaid stand mixer arm wobbles when I turn it on.
if the head wobbles on stand, flip mixer upside down, and tighten the pivot pin screw way deep down inside stand. you will need a long flat blade screwdriver. it's probably loose.
May 13, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The head has a lot of play and the mixer attachment scraps the botton as it turns
It sounds like the pin that holds the head on is not in the correct place. IT should not stick out on either side, if it is, knock it back so it is flush with the sides. Turn the mixer over and tighten the screw that holds the pin in place.
The second problem is that the head is too low. This can happen over time. There is a screw that can be accessed when you lift the head up. It is in the middle of the hinge. Adjusting this will lower and raise the head position when the head is lowered back into place.
Jan 24, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
I have to physically hold my Artisan mixer in place or it will go off the counter, even at low speeds. Seems to rotate fine as long as the head isn't down with an attachment on and in the bowl.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn.
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need to replace cord on vintage Sunbeam Mixmaster Junior
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
Mar 10, 2009 | Sunbeam Food Mixers
Kitchen Aid KSM90 300watt Ultra Power Mixer
According to the service manual this is the drip cup and is really only held on by friction. I have not tried to take my mixer apart yet but I would think that if your drip cup is too loose, all you need to do is come up with something (string, paper, saran wrap, etc) that will not actually glue it together but will add sufficient thickness to help hold it in place.
Dec 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Mixer doesn't run
you can take it apart by removing the pin which is in the shaft that does NOT hold the attachments....... i got mine out with a nail set and a gentle tap or two with a hammer. after you remove that pin the portion that holds the attachments will slide down revealing three more screws and some gearing. if you remove those three screws....... the top will come apart (assuming you have removed the other four screws which are visible when the unit is assembled) and you will see the circuit board.
Sep 26, 2007 | Jenn-Air Attrezzi JSM900 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
66 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
