I am trying to get a repair manual or brief info on a above ground water pump manufactuer name is well mate, serial # 24801463, in order to check the right pressure that is required and to get other info on it. I would like this info to be sent to me asap. There is not a pick one choice that applies for an expert.
  • 706 Answers
The serial number won't help me help you but here is a link to teh wellmate website and you should be able to contact them and/or get whatever info you need..
http://www.wellmate.com/links.htm
Regards,
Rick
Posted on Dec 13, 2008
Water condensate tanks keep filling up. Never needed to empty them before with many years of use.
Rick, check the hoses are not clogged or plugged. There is probably a small pump which may have quit and will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Air conditioner leaking in your basement Condensate pump Reliable Heating...
How to repair check Condesate Pump Little Gaint VCMA 15UL
How To Unclog Condensate Pump Tube
Jun 04, 2016 | Heating & Cooling
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
I need a belt for convair westwind swamp cooler Model M800CB UL serial #08 211046 Prod #: 008950 Belt runs from back of fan to the drive for the water pump. If you know where I can get one I would...
Hi John, your best bet for this, is to get the name and or number off of the belt, or take it off and go to any auto parts store and match it up. That's what we do in the field. If you try and order one, you will run in circles. Also, any appliance parts house will have one.
Shastalaker7
A/C Contractor
Jun 06, 2011 | Convair Portable Air Conditioner
I have a Redello water pump 1HP, the shaft had seized as a result of a bearing seizure. I have replaced bearing and shaft in motor can now be turned manually quite freely. however the pump will not kick in...
It was used rapidly at the time of shaft struck. Before changing the bearing you must have checked the windings continuity. I think your windings short circuited or grounded.
Check with ohms meter one end with one winding end and another on body of the motor. If any reading, it's grounded. Rewind the motor/replace motor.
Dec 27, 2010 | Heating & Cooling
I need a Daewoo fan motor for a carrier roof air on my rv
Hi; Question... is the unit still under any kind of a waranty if so dont touch and follow waranty info. If unsure call Your local supply house for warranty info. These people can also order Your motor if not under warranty. Caution please dissconect power to rv before attempting any repair. Also use a good penetrating oil like PB blaster found at auto stores on the hexallen bolts or any for that matter. The supply house will need make, model and serial numbers of unit and fan motor if possible.......
alpharome416
Feb 22, 2010 | Heating & Cooling
Sta-rite well pump. My pipes froze and now I have a leak. When I plugged in the pump to check which pipe was leaking it cuts on and off every 2-4 seconds. If fixing the leak does not fix this what should I...
Is the pump above ground or in the well ?
If its above ground, sounds like you have air in the pump which will not let it operate properly, if you fix the leak, you will have manually fill the pump with water from the access hole on top of the pump, its takes time and patients to do this as I used to live in Northern MN, and was on a well too, once in a while I would have to prime the pump do to water loss somewhere in the system, if it is a pump that is down inside the well, you will have to call your local well driller and inquire as to the cost of diagnostics and repair, hope this was helpful, thanks for your Question,
mr.grzz
Jan 22, 2009 | Heating & Cooling
Evapoative air conditioning
sounds like the flaot switch is stuck in the up position. this will be like the drain pan is always full of water. You may need to take the unit apart and check the flaot in order to reapir this problem.
Jan 24, 2008 | Heating & Cooling
How do I make the water flow down on its own?
Hi, I own 3 of these. They were not designed to pump water out. I actually have put them on bricks to increase the height above the tray I collect water in. (so gravity works) They also use water to help with cooling, which is vented out the warm exhaust vent. Actually, it's not the best design, but at least it works for a portable unit.
Sep 24, 2007 | Continental CE-PAC1163 Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
