Question about Kitchen Ranges
Error code f153 for right front burner on a GE profile range.
  • 734 Answers
Please follow the above link ----
http://www.enquirium.com/F-153-(153)-code-on-ge-touch-c-t-q5045203.aspx
Thanks
Posted on Dec 13, 2008
  • futureloginn
    futureloginn Dec 13, 2008
    ok,
    i'll find the error code ----- go to ----
    http://www.projectposner.org/case/1989/8...
    sum part from the link -----
    (trademark or returning the trademarked items to his supplier or otherwise complying with the terms of the license, the ex-licensee may continue to use the trademark. Two circuits have held that such trademark abuses (which are very old, see, e.g., Evans v. Von Laer, 32 F. 153 (C.C.D. Mass. 1887)) violate section 1114(1)(a). See Burger King Corp. v. Mason, 710 F.2d 1480, 1492 (11th Cir. 1983); El Greco Leather Products Co. v. Shoe World, Inc., 806 F.2d 392, 396 (2d Cir. 1986); Franchised Stores of New)
    Thanks
  • 4,472 Answers
Http://www.geappliances.com/service_and_support/
What is the exact model of your unit. Your best bet it to contact GE support as I do not find reference to that error on their site. You can also locate a service center on that page as well. If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Dec 13, 2008
    Most likely it is just from overuse of that one burner and the whole assembly needs replacement. Good luck and please take a moment to accept and rate my solution.
    Thank you,
    Lee
  • 2,326 Answers
Check the info from this link and see if that applies to your appliance. If your appliance is less then 5 years it might still have warranty on that part but you might have to install it yourself.
  • 275 Answers
Right front burner might need replacement soon.. part would cost you around $30.00 bucks. hopfully this helps you out!!
    Genius:
  • 1,199 Answers
This code has to do with a falty heating element have service man fix beforr useing that burner because it may cause more damage!
What does the code f153 mean
The profile means GE Kitchen Ranges and the code F153 means the two front elements (burners)
Jun 26, 2012 | GE Kitchen Ranges
The size of the flame on the front right burner is
Look down under the burner and make sure nothing is clogging the orifice.
Jan 29, 2010 | GE Profile Spectra JGB915 Gas Kitchen...
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Front left burner indicator light stays on and i get an F113 code when I try to use this burner
The "F113" error code means "Open temperature sensor".
The problem could be a bad sensor/wiring/ control board.
This stove is very complicated and you may be better to call for service.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 08, 2009 | GE Profile 30" Free-Standing 5 Burner Self...
GE COOKTOP JP950BKBB PROBLEM: F153 ERROR
one of the burners has a open heat sensor. Have to replace burner assembly.
Sep 17, 2008 | Kitchen Ranges
Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Jul 17, 2008 | GE 30 in.JP950 Electric Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
