Question about Honeywell Programmable Thermostat Heater
Wiring honeywell digital stat
I have just brought a new honeywell digital thermostat T6620B1008(DT200) and i am having trouble wiring it up.
all i have on the new stat is A.B.C.conections
I HAVE 3 WIRES RED BLUE AND YELLOW WITH A RED COLLAR ON THE YELLOW CAN YOU HELP ??????
CHEERS DAVE
  • 1 more comment
  • Anonymous Dec 24, 2008
    yes same problem. not good diagram on diag e; what is "M" thanks jon
    yea same prob diag 'e' what is 'M'
  • indpls42 Dec 25, 2008
    im having hard time connecting honeywell pro th 4000. old stat was a sc 2200 with emergency switch.. hw has no emergency sw.it heats but blower doesnt turn off and no cool air.. ty
  • 706 Answers
Hello davem1952,
The way you wire it will depend on how the other end of your three wires are wired into your heating system. This link http://www51.honeywell.com/pacific/common/documents/DT200_Specifications.pdf
shows the various methods for wiring it and take into account the type of setup you are dealing with. You'll need to find the wiring detail ( last page) that corresponds to your setup..
Hope this helps..
Reagrds,
Rick
Posted on Dec 13, 2008
Im trying to change my old mechanical Honeywell stat for this digital one.
what is the brand and model of your old and new thermostats ?
Apr 27, 2016 | Heating & Cooling
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Wiring honeywell DT200(T6620B)
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
Replacing old honeywell thermostat with digital model
Thought I could help but ?????? Not with ABC??/ DO you have any desinations on either thermostat that is Y G R W? Is this a mobile home thermostat?
Mar 21, 2009 | Honeywell Electrical Supplies
I have an existing 3 wire honeywell room stat on a conventional ch system which has gone faulty. I have bought a honeywell DT200 to replace it but this looks like it only takes 2 wires. Can I use this stat...
Hook up the Red wire to R on the t-stat and the White wire on the W just cut the wire flush with the insulation and leave it un hooked. If those are not the color get back with me. ken
Dec 16, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
524 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
