Question about Genius Cameras
Genius G-Shot HD55 (camera) - How to get SD card working??
I havea problem with my camcorder,
when I insert my SD card nothing happens and the camcorder is still recording into internal memory!!
User manual says:
Memory status indicator
Simbol A: SD card indicator
Symbol B: Internal memory indicator
But the say nothing about how to switch from internal memory to SD card or vice versa!!
And it's always showing me Symbol B, like there is no card!!
I tried this with classic SD card, 2GB capacity.
I double checked and the card is unlocked and correctly inserted, contacts facing downward.
HELP!!
Regards,
igor
For Genius G-Shot HD55 you need to insert the SDHC card deeper into the slot until it clicks closed, like opening a pen, then when you want to remove it press it again until it clicks to release, like closing a pen. Your card is recognised after the deep click insertion and restarting the camera.
Posted on Oct 01, 2011
Internal memory full
Internal memory is full after you shot only a few pictures Actualy you only have 11 Megabyte free for pictures. If you want to make more pictures, you have to insert a SD memory card. Make sure you buy a SD and not a SDHC or SDXC card, because nothing in the manual says your camera is compatible with these bigger cards.
If you happen to have a SDHC card you are free to try if it works, but don't buy one unless you are sure it works.
Jan 20, 2014 | Kodak EasyShare C913 Digital Camera
Do i need a specific type of sd caed for my camera to work
Are you sure you have an SD card, 2GB or smaller? The HDV146 will not work with higher-capacity SDHC cards.
Jan 26, 2013 | Jazz HDV146 Silver 8MP HD Camcorder, 2.0"...
When i insert sd card it say not supported card
Try formatting the SD card using your computer. Insert the SD card in your computer. Open My Computer, find your SD card drive, right click on it and select Format. Choose FAT for the filesystem and continue with the format. When the format is complete, insert the card into your DVD Camcorder and try again.
Feb 22, 2011 | Samsung SC-DX103 DVD Camcorder
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
I have inserted an SD Card (2GB) into my Alba pocket camcorder and nothing appears to be working on the camcorder. There is a small red light showing underneath the Rec and Zoom in/Out controls but apart...
Hi!
Have you inserted a new SD card? If this is already a used one, you can try to reformat it and then test with the Pocket camera again.
With the issue on the device recognition on your Windows PC, you should make sure that the correct driver is installed.
Will wait for your reply.
Aug 27, 2009 | Video Cameras
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Jan 06, 2008 | Sanyo Xacti VCP-HD2 Camcorder
SD CARD
If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
Feb 10, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
116 people viewed this question
Top Genius Cameras Experts
Are you a Genius Camera Expert? Answer questions, earn points and help others
