Question about General Electric Electrical Supplies
GE thinline cicuit breakers pop out
I have installed 2 GE thinline breakers but there is nothing for them to snap on to. They pop out
    Genius:
  • 1,199 Answers
I belive you need to retutn them and buy another type because thinline by GE is not compatible with all circut boxes!
Posted on Dec 13, 2008
  • 10,594 Answers
What is the specification of GE thinline breaker?
How to change a fuse in a GE Spacemaker XL Microwave
  • 1 Remove the old fuse from the compartment that the control panel was covering by grasping it and pulling it out. Place a new fuse in the compartment and push it firmly into the holder until it snaps into place. Connect the wires to the control panel according to the labels.
  • 2 Place the control panel on the microwave and install the retaining screw with the Phillips screwdriver. Install the grill on the microwave and snap it into place. If your microwave grill has retaining screws, install those and tighten them using a Phillips screwdriver. Plug the power cord in for the microwave or turn the power on at the breaker box and program the microwave according to manufacturer instructions
  • home light bulbs
    May 03, 2012 | GE Microwave Ovens
    Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
    1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
    2) Double check your T103 terminals
    T103 terminals should be A 1 2 3 4
    If terminals 3 and 4 have wires, then GE is not correct replacement.
    You can buy repair parts for Intermatic timer
    http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
    3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
    GE has terminals 1-L X 2
    4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
    http://waterheatertimer.org/GE-timers-and-manuals.html#15306
    White wires on terminal A connect to terminal X
    Black wire on terminal 1 connects to terminal 1
    Black wire on terminal 2 connects to terminal 2
    Sep 11, 2011 | GE Vacuums
    Thinking about buying a new GE range that has a 3000 watt specification ... our home is sixty years old and wondering if the wiring (240 v) can support the wattage. I don't know the wattage of our old...
    Calculating necessary breaker size using ohms laws, says 3000 watts at 240 volts would use 12.5 amps and most range circuit breakers are 30 amp so it should be find
    Aug 01, 2011 | GE Ovens
    I have a 2006 f-150 1/2 ton extn cab. the electric windows quit working. I am convinced it is a fuse on the main feed. Where is the fuse for the windows and what size ? The electric locks work fine.
    There is a 30 amp circuit breaker. The concept of the circuit breaker is to "pop" when there is an overload but is supposed to reset after a bit. That is not always the case or you could have a short in the wiring of the windows cicuit which also includes the rear sliding light. If that is the case of course it will keep "popping" But like I said I have seen them get weak and just replaced them. The location of that circuit breaker is in the passenger compartment fuse panel. It will be in the number 401 position. I gave you a diagram of the fuse layout below. I hope this helps and good luck.
    Jun 02, 2011 | Ford F-150 Cars & Trucks
    My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
    The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
    Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
    I NEED A CIRCUIT BREAKER IT HAS GTE SYLVANIA, ON IT WITH #8-176 CLASS A, HRGF. E 51616, R 10,000 A 120 VAC 60 N 2 CTL. PLEASE CAN YOU HELP ME LOCATE ONE OF THESE?
    There are companies that specialize in used / obsolete electrical distribution equipment. Larger areas may also have "brick and mortar" stores to shop. If no such store exists near you, try googling "used GTE cicuit breaker" When I did I got a bunch of results including this one:
    http://www.allbreakers.com/Products/
    I hope this helps!
    Oct 27, 2009 | Sylvania Circuit Breaker
    No power to cooktop and breaker isnt tripped
    maybe reason breaker kept blowing was a faulty cooktop
    Nov 07, 2017 | GE 30 in. JP340 Electric Cooktop
    30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
    I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
    Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
    Electrical Supplies Logo
    465 people viewed this question
    Top General Electric Electrical Supplies Experts
    Rob Bridges
    Level 1 Expert
    Craig Butler
    Craig Butler
    ken skalski
    Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
