Question about Lexmark Office Equipment & Supplies
I have a Lexmark X5470. The paper starts to feed and then it stops. Printer thinks it is printing ,but no paper in it.
    Problem Solver:
  • 33 Answers
The same thing happened to me once. Try looking near the cartridges and where you input the paper, there might be an item stuck which makes it hard to print or load the paper. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
If that doesn't solve the problem, try contacting the manufacturer.
Hope this helps!
Posted on Dec 14, 2008
My lexmark x5470 will start the print cycle paper starts to feed then stops then i get paper jam warning
Hello there Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print the paper slides in 3 inches and starts to crumble up and jams. Is there any way you can assist me with...
if the paper is crumpling up then something is stopping the paper from moving check the paper path for obstructions. if your first set of feed roller are moving and the second set is not then this will happen also
Dec 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper not feeding correctly
try to clean the carriage and see if a Q-TIP will reach the feed rollers. They probably still have some ink still on them.
Jul 31, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
X5470 Paper Feeder
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......
Good Luck......
Jan 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper feed jamming problem
had this problem also try looking for a tiny piece of torn paper in the feed wheel and remove the snag
Aug 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly installed won't stop jamming paper
Paper Jams in the Printer ID:412
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
