Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag washer hi i have a neptune front load washer(mah4000aww). It's just started not working. It will come on briefly when I push the start button, then make a beep , beep , beep noise, then turn off.? Can you help me figure out whats wrong? Thanks for reading this. Mary Mchugh
  • Anonymous Nov 03, 2007
    when start washing machine it will run and then stop inbetween cycles
  • Anonymous Mar 29, 2014
    My Maytag is a Neptune front load. When you push the start button the red start light comes on and you can hear the water start and the light turns off within seconds and everything stops. If I hold the switch down it keeps working, you can hear the relay click.
    President:
  • 1,294 Answers
It helps trying to actually weigh your dirty linen. Try to wash within what is mentioned in your manual. Also see that the door is closed firmly. Would be useful if you'd post back results.....
Posted on Apr 13, 2007
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like you have an intermittent problem with the board or one of the on board switches.
Oct 22, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
254 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
