Question about Uniden TRU8865-2 Expandable System Cordless Phone
I have a Uniden TRU8865-2 and I am trying to reset the base to clear non-exisistent handsets from the registry.
Unplug the power and phone cord from the base. Hold the find headset button and plug it back it continue holding the button until you hear a beep, then register the working phones.
Posted on Jan 02, 2009
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
The Uniden XDECT7055 Owner's Manual is unclear regarding setting up the day/time. When I go to the MENU/SELECT function and scroll down, the date/time is not one of the functions offers to set. The only...
Phoned Uniden - durrgggh - had the same problem - simple solution - advised them to improve the manual - is totally not clear!!!!
As below:
  • Day and time must be set in 12hr times - not 24 hrs
  • Must be set from a handset - any handset that is registerd to the base is fine
  • Follow handset instructions but make sure hours are set as 01 - press menu / select to confirm
  • Then place the handset back on its base - all other handsets and the BASE will then change to that day / time
Hope this helps
Dec 06, 2009 | Uniden Cordless Phone
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
Jan 09, 2009 | Uniden Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Dec 29, 2007 | Uniden TRU9488 Phone
Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Apr 28, 2007 | Uniden DCT648-3 Cordless Phone
Uniden TRU8865-2 Expandable System Cordless Phone Logo
326 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
