Question about Lexmark X1240 All-In-One InkJet Printer
Printer not communicating with pc - Lexmark X1240 All-In-One InkJet Printer
  • lsneedshelp Dec 15, 2008
    The pop up says not communicating. I have tried everything including parental controls, checking for active usb ports, restarting computer. All I did was move the location of the computer and printer. What do I do??
  • lsneedshelp May 11, 2010
    You are a genius...I would have never thought of that. I'm certain it will work. I was on the phone for two hours with tech support from Dell and Lexmark...no luck with them. Thanks!!
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install - (1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Posted on Dec 13, 2008
My Lexmark Z1420 Is not communicating with the P.C. Have checked everything and it tells me it cannot communicate with printer. The printer works with other P.C.
If its a Windows PC, you need to unplug the printer, Boot the computer in the Safe Mode, and remove the drivers (with the Device Manager). You might find duplicates. Remove them all.
Then reboot and install the drivers again, following the directions on the driver installer. Windows needs these extra steps.
Jan 26, 2015 | Lexmark Office Equipment & Supplies
Datamax s class printer not communicating with pc
1. Try to get a test page printed from the printer directly through the printer panel.
2.1 Check for the cable connector's both ends securly fitted to the PC and the printer.
2.2 Reboot the printer and the PC and check printing the test page.
3.1 Try swaping the connector with any spare from other printers.
3.2 Reboot the printer and the PC and check printing the test page.
3. Try Calling the Sevice Eng. or the Tech Support of the Printer.
Jun 09, 2012 | Datamax S-Class Thermal Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1190 problem communicating with computer
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Printer will not comnnect to the network wireless model brother dcp-585cw
People usually think connecting a printer via wireless is as simple as connecting a PC. However it is not the case. A printer need to communicate with every PC in the same internal network, however each PC will not communicate with other PCs in the same network to protect it private files and also the firewall settings. Next every PC is set to get a dynamic new IP address from the DHCP server everytime when it is powered up and plug into the network. But the printer need to get the same fixed IP address when it is powered up in the LAN.
So the Printer in a LAN need to set up a fixed IP address such that everytime when it is powered up, it has the same IP address that each PC could still get communicate with this Printer. Apart from setting this in the Printer, you also need to reserve this Fixed IP address with your Printer's MAC address in your DHCP server of the router. Otherwise it will get conflict with other PC or device that could have assigned the same fixed IP address. Then you have to setup your Firewall of your PC to let communication to this Printer. Else it will be blocked.
Lastly make sure you install the printer driver correctly in your PC with the same Win OS version such that it could detect the fixed IP address of your printer. Then it should work correctly.
Please let us know any problem you may have in future.
Aug 14, 2011 | Brother DCP-585cw All-in-One Wireless...
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Does not communicate with computer
Please disconnect it from the PC
uninstall the drivers, then restart your PC
then after you restart put the print disc in the cd drive of your PC
then once it prompt you to connect the printer connect your Printer to your PC
install and restart the PC
Your computer should have no problem in communicating with the printer
Jan 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
Communication Error
Hi there
Communication Error with the PC maybe it needs to ubinstoll the printer driver and then close down the PC and restat up again and then put back the driver, this may work.
All the best Pineworks
Apr 28, 2010 | Lexmark X3550 All-In-One Printer
Printer cannot communicate with printercommunicate
I would suggest:
Go to Printers and Faxes and delete your printer icon
Disconnect your printer's cable (connected to your PC)
Restart your PC
Reconnect the printer's cable
Your PC should see the printer and install the printer's driver software.
Hope this helps.
Sep 08, 2009 | Lexmark X3650 Printer
Printer & PC not communication
Did you delete all printers before instaling drivers so that you would have a clean printer install .
delete all printers first from control panel via printers and other hardware. then reload printer drivers for this printer.
Jan 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
