Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Netopia 2247NWG for smarttelecom
Connection setup details as follows:
VPI: VCI: Protocol: PPP over Ethernet LLC/SNAP PPP over Ethernet VC muxed RFC-1483 Bridged Ethernet LLC/SNAP RFC-1483 Routed IP LLC/SNAP PPP over ATM LLC/SNAP PPP over ATM VC muxed Bridging: Disabled Enabled Concurrent Bridging/Routing: Disabled Enabled User Name:
Password:
Confirm Password: Static IP Address: IP Gateway: Primary DNS Server: Secondary DNS Server: Connection Type: On-Demand Always ON Manual UPnP: IPSec PassThrough:
The result is as it follows:
Connection Information DSL
Down
eircom broadband
Disconnected User Name
IP Address
84.203.2.32
IP Gateway
0.0.0.0
Primary DNS Server
84.203.254.34
Unavailable
84.203.255.34
Unavailable
Speed
0/0 (kbps)
Line Attenuation
0/0 dB
Could anyone help me to solve the problem? Everytime it fails to connect to ISP (eircom) although IP and DNS data belong to Smarttelecom.
Thanks in advance
    Problem Solver:
  • 13 Answers
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Posted on Feb 06, 2009
  • helenmagro Oct 12, 2010
    This also worked for me when I brought my Netopia 2247NWG EIR router to another country - i.e. Malta in my case! Thanks so much!!!
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
Feb 25, 2010 | 2wire 2700HG-B Router (2700HGB)
ADSL setup problem for O2
You need to manually configure the router.
Connect a computer directly to the router using ethernet cable and access the router page using address http://192.68.1.1
Username = admin and password = password
Click on ADSL settings in the left hand side menu. Enter the requred infor VPI= 0 VCI =101. Select the required multipexing mode.
Hope this helps.
Jun 20, 2009 | NetGear RangeMax Dual-Band Wireless-N...
How do i change mtu setting in motorola 3347
the gateway of the router is actually 192.168.1.254
Then you click on home, configure, wan, then PPP over Ethernet vcc1 under WAN IP Interfaces, then advanced at the bottom.
Click advanced at the bottom.
Under LCP settings, They call it MRU
that is the same as the MTU, which stands for Maximum Transmission Unit, and the default is 1492. some routers put in 1500, but they are rounding off. If you reset the MTU, set it to 1468, it has to go down evenly in 8's, because you are talking about shapping the data packets that are coming in. Only do this if you are connected no browse, or cant get cerrtain websites. Not all routers can handle jumbo packets, but to be honest, I have never seen an MTU issue on a netopia, and I deal with problem issues on netopias all day long.
spin
Jun 16, 2009 | Netopia 3346N-ENT Router (3346NENT)
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
How do i configure my dlink 302g modem to my new ISP's settings?
Hi Nitangel
Before proceeding with modem installation you need to gather your connection details from your Internet Provider. You will need to know or find out the following information about your new ADSL connection from your Internet Service Provider:
Connection Type:
PPPoE
PPPoA
Bridge RFC1483
Default IP address: 10.1.1.1 (USB 10.1.1.2)
Username: admin
Password: admin
· Username / password (PPP connections only)
· IP address / Subnet Mask / Default Gateway (Bridge connections only)
· DNS IP Addresses (optional)
To set up, log into the modem using your WEB browser: type http://10.1.1.1 in the address bar and press Enter.
Enter username 'admin' and
password 'admin' (default setting).
Go to Quick Configuration page.
Set Refresh Rate to "No Refresh".
If it is a PPPoE or PPPoA CONNECTION:
Select Operation Mode: PPP.
In the Connection Type drop-down menu select PPPoE or PPPoA profile.
Enter username and your password.
Select CHAP under Authentication Type (check with your ISP if not sure).
If it is a BRIDGED RFC1483 CONNECTION:
Select Operation Mode: Bridge. If you do not see "Bridge" options please update your modem's firmware at http://www.dlink.com.au/tech/
Select LLC or VC Mux as suggested by your provider.
Make sure your VPI/VCI is set according to your ISP requirements:
Click on "Save & Reboot" to save settings.
Then give modem a minute or two to reboot and reconnect. Restart your computer and you should be able to access the Internet.
You do not have to run any login client on your computer or router because your modem logs to your ISP automatically.
Hope this information helps if I can help further let me know.
Jun 17, 2008 | Computers & Internet
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Thomsom speedtouch router
set your router to Protocol = PPPOA, VPI = 0, VCI = 38 Encapsulation = VC-MUX , your username is usually your phone number followed by @talktalk.co.uk or @talktalk.net & your password in the password box (these should be on the letter sent by talktalk when you registered.
Feb 09, 2008 | Computers & Internet
BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Jan 14, 2008 | Computers & Internet
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
1,623 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
