Question about Sony KP-53HS10 TV
My sony kp53hs10,the standby light blinks ,with no picture.
  • 6 more comments
  • bobby38 Dec 13, 2008
    all the time,there is no pause in the blinking
  • JG_song Dec 31, 2008
    Standby light flashes continued. Maybe diagnostic circuit board is bad. What is this board called? D Board or DS board, or else?
  • Anonymous Jan 02, 2009
    Anybody have solved this problem yet?
  • mccurtis Jan 28, 2009
    I have the same problem. My standby light flashes continually, and the screen remains dark. Looking forward to getting a solution.
  • Anonymous Feb 05, 2009
    FLASHING LIGHT
  • TVproblem424 May 26, 2009
    I have the same problem. Any help. I pulled the plug and put it back and it is still flashing for ever.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    TV has self-diagnosis function and standby light can blink 2 to 8 times depends on its problem.
    There would be pause / interval of 3 seconds in blinks and you can count its blinks after pause to next pause.
    How many times standby light blink?
I've got exactly the same problem. Initially, I saw it flashing twice, pause, twice, pause, twice... I pulled the plug when it failed to respond at all. And then when I plugged it back in, it went into the continuous flashing mode. Halp!
Posted on Feb 03, 2009
4 Suggested Answers
roety
  • 585 Answers
SOURCE: no picture
first of all sony uses blinks as a means of an error code, on older models like yours could be weak CRTs, try turning up the screen controls a little, if the picture comes on the CRts are weak and AKB is holding them dark. the controls are in the front behind the cover.
possibly you have no high voltage, D board or splitter is bad, bad convergence ICs will cause NP, check the 3.15amp fuses if any are blown replace ICs both stk392-110 and fuse to fix.
Posted on Jul 31, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: Sony TV standby blinks 5 times picture comes and goes
TRY TO TURN SCREEN CONTROL UP OR DOWN
Posted on Aug 26, 2009
chesterpendi
  • 195 Answers
SOURCE: my Sony kp53hs10 turns on and has a picture but
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply section..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
Sony kp-53hs10 wont turn on blinking standby light only
This may be beyond fixing: see http://www.techlore.com/forum/thread/20738/Sony-KP53HS10-5-blink-repair/
Dec 04, 2010 | Televison & Video
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
No picture
Jul 31, 2009 | Sony KP-53HS10 TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Standby Light Blinking
The service manual is for the technician who knows how to troubleshoot electronic circuits using the schematic diagram and test equipment. There is no such thing as a trouble shooting section in Sony service manuals. My best advice would be if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Apr 09, 2008 | Sony KP-53HS10 TV
Standby light is a signal indicating a voltage trouble on your system . It could mean a compoment is defective or a power regulator needs replacement worse is a system IC replacing. you better bring your stuff to a Sony service center and do a check on your TV system.
Just sound
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 26, 2008 | Televison & Video
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KP-53HS10 TV Logo
471 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
