Question about HP LaserJet 1320 Printer
HP 1320 will not power up
During a long print job, the printer just stopped with the yellow warning light flashing. No errant paper, no problem with toner, no misfeed, no jam. Power-down/power-on sequences have no effect. Does not power up, that is, no motors. Each time lights cycle between green and yellow, ending up with flashing yellow, completely silent. Hard reset does not work.
  • work113 Dec 13, 2008
    Found the problem. bottom back door off hinge, hidden paper jam.
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
Posted on Dec 14, 2008
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
Problem with HP 1320 printer
If the paper size in the word document is set to something other than "letter" example if it is set to legal. Then the lite is lit to let the printer user know it is waiting for him to place a sheet of legal paper in the printer, he does so and then presses the green button to start the print job. You can check this by going to "file-page setup" in word and look for the paper size setting.
Jun 24, 2009 | HP LaserJet 1320 Printer
Hp laser jet 1320 stop printing
Try unplugging the power cord and plugging it back in. Check to make sure that there are no paper jams or foreign objects stuck in the rollers. Reseat the toner and make sure the lid is firmly closed.
Jun 19, 2009 | HP Laser Jet 1320 Printer
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
Warning light flashes every 3-4 prints
hi
the reason why its doing that is your fuser needs to be refurbed. the teflon film of the fuser in your printer heats up alot and under the film is a silicon heat resistant compound that turns powdery or drieds out after a while. if the film is ok then your fuser only needs to be cleaned and regreased with new compound and then your printer is as good as new again
Jan 08, 2009 | HP LaserJet 1320 Printer
How do I "right clk explain. point icon" to open it up?
hi  check your pickup roller under the tray. pull out the tray and see just above it if the pickup roller is not broken or warn that can be your problem most likely. the light flashing jams it is like a jam occur because no paper was picked up by the feed assembly of the printer and there is a flagto tell it if a page came through.
Dec 27, 2008 | HP LaserJet 1320 Printer
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
Green light is flashing and printer will not print. It has paper and a new toner cartridge.
try putting a piece of paper in the tray 1 (Bypass) and then pressing the green button hopefully it should print. If it does then you have sent a print job to the bypass and not the tray. If you press the green button and it prints form the tray check what media type you have set within the print driver.
Hope these work for you
Thanks J
Jan 07, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
267 people viewed this question
Ben Johnson
