Sony KP-53S65 53" Rear Projection Television Logo
monty mooring Posted on Mar 12, 2007
KP-53s65 multipule problems, hoping for single solution?
Dear Professionals, Several symptoms and hoping that they have a common cure? 1) When TV is turned on, I have a fuzzy picture, as I change channel, the screen turns blue with diagonal lite blue lines and very faint images of recieved channel in background. Turning the TV off and back on clears the blue screen and returns the picture, but only until I attempt to change channel. 2) The viewable TV picture looks blurry with minor light fluctuations and a blue hue outlined around all dark colors. 3) As I attempted to align colors, the red aligned fine, however, the blue is so blurry that I cannot exactly tell where it needs to be set. A things I noticed: as I covered the all but the red crt, no light fluctuation and picture seemed fairly ledgable. as I covered all but the blue crt, the picture was very blurry (non-ledgable), but no light fluctuation was observed. as I covered all but the green crt, I had light flucuations on the channel I was watching. It there are any test or if there is more information I can provide please let me know. As this TV is 10 years old, I do not want to dump too much money into it and any help you can provide would be greatly appreciated. Although I am a novice to TV repair, my electronics knowledge is above average. Regards, monty
  • monty mooring Mar 12, 2007
    I was thinking about one of those new plasma screen anyway. Thanks for the input.
Anonymous
Level 1:
  • Contributor 53 Answers
  • Posted on Mar 12, 2007
Anonymous
Contributor
Level 1:
Answers
53
Questions
Helped
9806
Points
84
Sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Our Sony KP-51WS510 TV has a blurry and doubled "neon green" picture. What we can do? Thanks for your help!
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
When I turn on my sony (KP 53S65) the screen doesn't light up
The most common problem for this TV is a bad capacitor (C514)
Call a good TV Tech and have him check for that first. Should be a $125 job at the most
I need to replace the bulb in kp-53s65
This TV does not have a lamp only 3 CTR tubes which bulb are you looking for?
1helpful
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
2answers
Sony kp-53s65 rear projection
C514 is a ceramic capacitor its ratings are 390PF 2KV @10% tolerance
Multiple problems, hoping for one solution
sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
