Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have a Kenmore Coldspot frig with through the door ice and water dispensing. I changed the floor level water filter with the correct Pure filter. When I did, the water stopped flowing. I took out the new filter, replaced it with the older, and the water still will not flow. The valve is working; I can hear it when I trigger when attempting to get water. But the water has stopped flowing. I checked the back of the fridge to find out if the plastic piping had crimped. No. Where do I look next?
  • lgrella Jan 03, 2009
    I also have the same problem. I have a kenmore coldspot fridge, and the water stopped dispensing when I thought I needed a new filter. I replaced the filter, and the water started working for one day, and then has not dispensed since. The ice maker works fine. The dispenser clicks and buzzes like it is dispensing but no water comes out.
  • El-Man Jan 24, 2009
    My Model is 58285891, and just as the previous writer:
    1. I replaced the filter
    2. pumped the reset 5X within 10 seconds
    3. Green light
    4. No water
    5. No sound
    6. Bupkus
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
  • 58 Answers
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Posted on Oct 31, 2007
aborcass
  • 2651 Answers
SOURCE: Kenmore coldspot refrigerator
checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
Posted on Mar 15, 2008
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
docjohn174
  • 943 Answers
SOURCE: Ice maker problems
hi thanks for the question when you switched the wires around you checked the valves . tey are ok is the arm in the ice maker down check that if that's ok then the problem is with ice maker thanks for the question the appliance doc
Posted on Sep 27, 2008
Why has my Kenmore coldspot 106.54609300 stoped dispensing water and making ice?
if it not getting enough water pressure it will not work. check your line going to it if it's ok turn water off then where the water line goes to the frig unscrew it check the filter.
Jul 30, 2014 | Refrigerators
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot 10650522100 - water not getting to icemaker
look and inspect closely why the water is not going down the ice tray. maybe the soft hose to lead the water down to the tray is kinked or broke.
check also if there are still ice in the tray, they could have not dropped yet that is why water is just overflowing on the tray.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
