Question about KitchenAid KCMS145J Microwave Oven
Replace microwave door
I have a new door for my Kitchaid microwave. I have the case open but don't see how to remove/replace the door. The hinge pins and receiving holes do not seem to be removeable?
  • XDJ1 Mar 12, 2008
    I have a KitchenAid KCMS185JSS and have the same problem. I have a new entire door assembly but cannot get the old door off of the hinges, please help, Thanks.
  • KitchenAid Master
  • 9,156 Answers
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 On exploded view diagram 4, look at reference part number 4. That is the choke cover. It's held in place with hidden tabs. I've attached a diagram from a Sharp model that will be somewhat similar. Once the choke cover's off, the hardware should be visible. The diagrams do not show the hinged at all. That may mean they're welded to the chassis of the oven. Write back if this does not clear it up.
Posted on Mar 13, 2007
Replace door
If you're replacing the entire door, this is a very simple process that only requires you to open the door all the way and lift straight up at the hinges. The door lifts off the hinge pins, and the new one can be reinstalled by aligning it back on the hinge pins. (You may have to remove the hinges from the old door and install them on the new one on some models). NOTE: In some cases you may have remove the upper grille guard to accommodate lifting the door. The mounting screws for the guard on located across the top of the oven. If you only need to replace the door handle, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 26, 2011 | GE Spacemaker JVM1540 Microwave Oven
Door trim is cracked
you need to remove the screws to replace the door
Sep 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can I buy a new door. Current door is cracked on the corners.
You easily replace the door on most microwave ovens by opening the door all the way up and lifting straight up at the hinges. The door should lift off of the hinge pins. On some microwave ovens, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can may try to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. Some manufacturers only sell the door as a complete assembly. Others may sell individual parts. To save money, you may also try just purchasing the door facing parts that are cracked. If you have any questions, or require additional assistance, please post back with your complete MODEL NUMBER and let me know. I hope this advice is helpful.
Dec 16, 2010 | General Electric Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Need to Replace door on a sharp R1830 B how would I go about doing this?
On MOST microwave ovens all you have to do is open the door all the way and lift straight up at the hinges. The door simply lifts all the hinge pins. You may have to remove the upper grill cover (if equipped) to accommodate.
NOTE: On some models there is a small hinge pin on the upper hinge that you need to remove first.
If you have questions, please let me know. I hope this helps you.
Oct 08, 2009 | Sharp Microwave Ovens
On the GE JVM 1650 Spacemaker microwave, how do I replace the door?
If replacing the entire door, all that is required is to open the door all the way open and lift straight up on the hinge side of the door. The door will lift off the hinge pins. You may have to remove the upper grill cover (if equipped) on some models for better access. If you have questions, please let me know. I hope this helps you.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
I have a Kenmore model #721.89940490 The door handle broke off and need to replace it, I do not see any screws. how do I access the mounting screws.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. , but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door. In order to access them you have to remove the inner door frame. You can find how to remove it in the video clip from one of our previous posts.
Aug 03, 2009 | Kenmore 62702 Microwave Oven
How to replace the whole door unit
This should be a fairly simple procedure. To replace most microwave oven doors, all you have to do is open the door as wide as it will open and then lift straight up. The door will come off the hinge mounting pins and lift off. Install the new door by holding it in the open position and aligning it properly on the hinge pins. NOTE: On some models, you may have to remove the upper trim above the door. I hope this helps you. Let me know if you have further questions.
Jan 03, 2009 | Maytag MMV5000 Microwave Oven
Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Aug 10, 2007 | Sharp R-1610 Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
156 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Craig Butler
Craig Butler
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
