Question about LG WM2277 XL Front Load Stackable Washing Machine with 7 Washing Programs in 3 Colors ....
Drip tray for LG washer
My washer is on the second floor. Do I really need a drip tray? The reason is that it doesn't fit with the current drain hole. What are the chances a new washer will leak?
    Sergeant:
    Champion:
  • 291 Answers
All washers will leak for one reason or other / eather over load or shaking or something so be safe and get a pan that will fit and save your floor and ceiling
Posted on Dec 13, 2008
GE side by side refrigerator model no TFG20JAWWW 627 litre is occasionally leaking water
Check the drip tray in the freezer section where defrost water drips from the defrost heater melting frost during the defrost cycle. If ice blocks the drain hole in the tray inside the freezer(usually behind the evaporator cover) the defrost water will travel into the bottom of the freezer & onto your floor. Some models also have a second evaporator in the fresh food section. A blocked drain or clogged defrost drain tube can cause the problem.
Apr 16, 2018 | GE Refrigerators
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Water drips in refrigerator. I think it has to do with the defrost feature, which seems to drip only periodically.
You are correct. the defrost drain is most likely plugged up causing the water to drip into the refrigerator through the air returns in the ceiling of the fridge.
To access the defrost drain hole in your model you will have to remove the back wall from the freezer compartment and possibly the floor of the freezer as well if it has the floor air flow tray.
The repair is quite simple- remove as much of the ice as possible (i use a putty knife to pull it up in as large chunks as possible and then use a moistened dish towel to pick up the smaller pieces.
Use a turkey baster with some hot water to "plunge" the drain hole out. The drain hole is located in the bottom center of the evaporator opening.
Jun 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water draining into frig
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 06, 2009 | GE GTS22KBP Top Freezer Refrigerator
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Washing Machines Logo
359 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
