Question about Whirlpool GGX9868J Gas Dryer
MY 6yr old Whirlpool gas dryer mod.LGR7648KQO does not fire up ,I have cleaned all parts .Thank you IKE
  • 15,935 Answers
It appears your thermistor or gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
My new Perfect Care Gas dryer stops with in a minute of running.
Check your thermo coupler (flame sensor). If it's new it should have a warranty I would think.
Apr 10, 2010 | Whirlpool WED5520SQ Gas Dryer
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
I dropped a sock into the dryer filter how can I retrieve this
Fish it out with something. It may get in the impeller blades or catch fire.
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool mod # WGD5300SQ0 gas dryer gets hot but does not stay hot Is it a thermostat or radiant sensor or something else
by all means when dealing with natural gas consult only trained professionals....as natural gas does not have an odor..the odor that you smell is an actually additive that has been place for just this reason.
May 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool model LGR7648KQO does not heat.
Hi. By "heating coil" I am assuming you mean the dryer's ignitor?
What is probably wrong is the white thermal overload has opened up. You will find it mounted on the blower duct and usually has two light blue wires going to it with smaller spade terminals than the rest of the thermostats. You check it with an ohmmeter for continuity. This is a very common problem on those dryers and it usually opens up if the dryer vent is obstructed or needs to be cleaned.
The part number for this thermal overload is a
3392519. On your model, you have to take the back off the dryer and look for it to be mounted on the blower duct. You can't miss it. It's white plastic with a brownish colored center (looks like epoxy) where the terminals are.
Hope this helps and good luck. Thanks for using the FixYa service.
Mar 15, 2009 | Whirlpool Dryers
Dryer does not get hot
Most likely your heating element has gone bad. This will happen from a number of different things ranging from just plain age to clogged vents causing it to overheat and go out. Also with a gas dryer your thermostat may be bad. The thermostat tells the dryer when to release the gas and ignite the flame to heat the drum. This would be my first suggestion on what the problem is. There is also a thermal fuse on your dryer that may be the problem but I really think it's the thermostat. It's hard to say without hooking a volt meter to it to find where the current is stopping but these would be the most common causes. It's always a good idea to have your vents cleaned out at least once a year and if you have a long distance between the dryer and the vent outside get the entire hose cleared out yearly. This will save you money in the long run on parts and save you from any fires. With gas dryers, I have seen it a few times in homes, the lint catches fire due to the open flame and does a lot of damage.
Do try out the thermostat first, it shouldn't cost you but around 20 dollars for it. If you open up the back panel of the control panel you will find the wire diagram and it will show you where the thermostat is located. Do make sure to unplug the dryer first though. Trust me, 110 volts of electricity is not a fun feeling for anyone, I know from experience. If you have any other questions let me know. I hope this helps you out enough to get this fixed, I know what a pain it is to have your dryer out. Good luck.
Jan 22, 2009 | Dryers
No heat gas dryer
hi look for the thermal fuse at the back where you cleaned . its a small plastic piece with 2 small blue wires . replace this part thanks
Oct 06, 2008 | Whirlpool Dryers
Whirlpool clean touch dryer
Sounds like the wire that goes to the flame sensor switch if it is gas there is a black wire and a white wire that goes to it its on the left side of the gas valve on the flame housing tube / pipe
Aug 26, 2007 | Whirlpool LGQ9858P Gas Dryer
Whirlpool GGX9868J Gas Dryer Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
