Question about RCA P52830BL 52" Rear Projection Television
RCA P52830BL picture is bowed and colors separated.
My RCA 52" projection screen tv just quit working. When I turned it on last night, it made a loud "popping" noise, then the power went out in half of my house. I turned flipped the circuit breaker and turned on the tv. It now has the picture bowed on the top and bottom. The picture is also separated into the three primary colors. Is there a fixable solution, or is it time to give up on it? It is 12 years old.
  • Jolene Lien Mar 14, 2007
    I haven't had time to get to a repair person yet, but I will update as soon as I am able. Thank you so much for your response!
  • Jolene Lien Mar 29, 2007
    Thank you for your replies. I don't know if the solution would have worked. The parts were too expensive, so I chose to buy a new set instead. Once again, thanks for the reply!
I've got an RCA model P52830BL, CH#PTK195BB. Everytime I replace a new convergence card for this tv, it blows. Can you give me some advice as to what is causing this? I got another card, and turned on the set for about a second, and saw the screen was still messed up, and I quickly turned it off, to prevent this circuit board from frying, too. Thanks in advance.
Ken
Posted on Dec 09, 2007
I had the same problem last year. I bought a DIG CONV IC chip for around $20.00 and it has worked great since.
Posted on Jul 09, 2007
    Sergeant:
  • 308 Answers
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Posted on Mar 12, 2007
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Televison & Video Logo
278 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
