Question about Roper REX4634KQ Electric Dryer
Roper dryer wont work
It kicks on automatically when you turn on timer switch then after a few seconds it kicks off. It even does it with the door open. help
  • Roper Master
  • 8,205 Answers
Disconnect power from unit. The motors centrifugal switch is stuck in the on position. The switch mounts on the motor and when the start button is pushed during normal operation it powers up the motor just long enough to set it in motion. Spring loaded counterweights fly out and apply power to the run windings of the motor. The heater element is also energized as well. If it was me I would tear down the dryer and clean it up. OIl the switch, get it unstuck and retry. To get inside the dryer:you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Take the idler loose and get the drum out. Get a vacuum and clean the moter and inside real good. Oil the switch and get it free. This is not very difficult.
Posted on Dec 16, 2008
Timer clicks on dryer but want work
A lot of times the small white fuse will melt and kill the door switch circuit on these.
I removed a bunch of junk from this one's blower housing/filter chute:
So if your door switch is fine check the thermal limit:
Ya might want to give that Roper dryer a good going over. I did a complete overhaul of a Roper dryer and took some photo's for DIY folks: Roper dryer tuneup
Nov 02, 2011 | Roper REX4634KQ Electric Dryer
WILL NOT COME ON .IT HAS LINE POWER FOR SUPPLY BUT SWITCH DO NOT START THE DRYER .whirlpool roper dryer
check the door switch. if the machine think the door is open, it will not start.
just locate the switch that the door would normally hit when you close it. operate it a few times with your finger. you should feel or hear a click when the switch closes. if you don't, the switch will need replaced.
other than that your timer is suspect. it is much more expensive to replace. good luck
Nov 06, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont start on my roper dryer. Timer is working but wont start
Check for a blown thermal fuse. It's about an inch long and is located inside the rear of the dryer usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Dryers
Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Mar 16, 2009 | Roper REX4634KQ Electric Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
114 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Roper Dryer Expert? Answer questions, earn points and help others
