Back to:
Tags:
Emerson EWC1304 13 in. TV/VCR Combo
EWC1304 VHS tape shuts off entire system
posted by DevilAnse on Mar 12, 2007
I am having a problem with the above mentioned TV/VCR combo shutting off when I insert a tape. There isn't anything obviously damaged in the cassette carriage. The tape loads a little unleveled.
The TV works fine for days on end with out any problems, so I don?t think it is a power supply problem. I do however think it may be a jam in the tape playing mechanism. I hear the tape try and feed to the heads then the power goes off.
I have to push the power button and the system comes right back on, lending to the thought that the power supply isn?t the problem.
Any ideas?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 12, 2007
Helpful (85)
henlopen
Rank:Wiz Wiz
Rating: 84%, 610 votes
You probably have a bad or dirty mode select switch. Another possibility would be a gear out of time if a tape was forced in too quickly.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on EWC1304 VHS tape shuts off entire system:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
I hooked up my dvd player, the tv isn't hooked up to...
is it possible to change this tvs pal settings from 50 to...
please tell me how to program my tv without the remote.Its...
The volume level on my Emerson TV/VHS combo will not...
We have this emerson tv/vcr combo, we have had a dvd...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
