Question about Roper REX4634KQ Electric Dryer
Not heating where is the model number located on roper dryers?
  • Anonymous Dec 29, 2008
    igniter not starting
  • kylea01 May 09, 2009
    I have a brand new roper dryer that the fuses are always dying on me at least once a month i have to change. I have 220 going into the dryer what do I look for to solve this issue.
  • 85 Answers
Model #s are located on panel inside of door. check breakers, heater and thermal fuse always disconnct electrical power
Posted on Dec 16, 2008
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
The dry wont run on high heat cycle but will run on the low heat cycle
Could be the Hi Limit Thermostat causing problems. There are over 350 Roper Dryers. Not much can be diagnosed without knowing the actual model number of your dryer. Please drop a comment with full model number. You can view the parts by selecting the correct model from this site.
RoperDryer Parts
Sep 02, 2014 | Roper Dryers
Roper gas dryer model rgd4440vq2 drum turns no heat have front off checked for power seems to be good i can only think the igniter is bad do you have a pic of part so i can compare it please!!!!!
YES!
If you will type in "Sears Parts" you will be given a place to enter your model number.
I tried it and it came up as"not a good number".
You try it.
That web site has complete diagrams for all machines.
Be blessed.
Feb 23, 2013 | Roper 29 Gas Dryer
I have a roper electric dryer model number is RGL4632DWO and I have purchased the coils for it, my question is where are they located at? I don't want to tear it a part without knowing about where they...
Remove plug from wall socket.
Remove back from dryer.
On the right side you should see a sheet-metal duct/tube.
Label and disconnect wires to parts going into this duct.
Remove duct.
Heating element (coils) should be in lower portion of the duct.
Jul 08, 2011 | Roper REX4634KQ Electric Dryer
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
How do I replace a heating element in a Roper clothes dryer? I get no resistance across the element with my ohm meter so I assume the element has been broken or burned in two. I can not find a way to...
I am not really familiar with your particular model number but most roper dryers have the heating element in a thin metal housing that is rectangular. The housing is part of the heating element and comes with the new one. Usually you just take the screws out of the outside of the housing and it comes right out. I hope this helps.
Jul 03, 2010 | Roper REX4634KQ Electric Dryer
No heat
If this is a Whirpool model dryer (this includes Kenmore, Estate and Roper), the heating element will be located on the lower right hand side with the back panel removed. If the dryer does not have removable back panel, the heating element will be located inside the dryer under the drum on the right hand side.
Since you posted no brand name or model number, I'm going by the heading you posted this under. If your dryer model is different, please post back with your correct information so that I may assist you better.
If you have questions, please let me know. I hope this answers your question.
Jul 03, 2009 | Whirlpool LER5636P Electric Dryer
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
166 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
