Question about Aprilaire 700 Humidifier
What should my humidifier be set at for the winter?
I have a 5 year old Aprilaire 700. It seems dry in the house and it was set at 35%. How do I check to see if it's even working?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Posted on Dec 15, 2008
There is a lot on condensation coming out of the pvc from the house. I have it set on 35. I changed the filter and now it seems to be running all the time. Is this right?
Hello, the humidifier should turn on and off with the furnaces blower motor. Usually if it runs continously it means the solenoid valve is stuck open, in this case the solenoid valve must be replaced. The condensation is normal comming out of the pvc pipe, and the humidistat should be set according to your outside air temp
Outside Temperature -10 F 0 F 10 F 20 F 30 F Recommended Indoor
Relative Humidity
20% 25% 30% 35% 35%
Feb 21, 2011 | Aprilaire 700 Humidifier
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
Is it worth fixing my aprilaire 112 which is 17 years old or replace it with a model 700
I would advise you to replace your old humidifier. The reason for this, is that at 17 years old, you will probably find that parts are scarce, and fixing one thing only breaks another. Also, the old humidifiers, by design, are a perfect breeding place for mold and algae, and switching to a new flow through type is advisable.
Dec 19, 2009 | Aprilaire 700 Humidifier
Is there a url that compares all the whole house humidifiers?
go for the Aprilaire 600 but make sure they install the outdoor sensor and set it up for AUTO operation
Oct 01, 2009 | Aprilaire 600 Humidifier
Aprilaire 700 Humidifier not working. Can it be repaired?
turn the humidistat back up, aand make sure if is still wired up.
Jan 18, 2009 | Aprilaire 700 Humidifier
The water flow valve doesn't seem to be letting water through to
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf Read page thirteen and there is a inlet water filter that may be cloggeed. Let me know if you need anything else.
Jan 11, 2009 | Aprilaire 600 Humidifier
Aprilaire Humidifier Model 560 - Humidity Not Rising in House
water trough on top filling up. do not clean it too much as crud distributes water across top better.
Dec 25, 2008 | Aprilaire 700 Humidifier
After one season the model 700 doesn't turn on
clogged solonoid? clean filter and orifice
Dec 13, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
6,220 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
