New hp dvd writer... no sound from dvd's
I've just installed above dvd writer with bundled nero esentials7. I was able to install a new program via dvd writer (reason for purchase), however, when I attempt to play a known DVD, I am able to only see the video portion without soundtrack. Can you help?
    Master:
  • 416 Answers
First double click on speaker image in right corner of your screen to see if you have MUTE disabled for all the devices and you have audio drivers to have speaker activated. Second, if you recently istalled new dvd driver it can be hardware problem. There are audio plugs (analog and digital) on back of DVD-Burner. Check if they are connected properly. Third your DVD-playback software might not supporting audio, so you might be missing audio codecs to playback DVD-audio. It depends which program you using. Maybe you need to download another program to playback DVD, for instance Windows Media Player 11.
Good Luck
Posted on Dec 13, 2008
When trying to upload application programme for external dvd writer once nero 7 has been installed, message pops up saying disc is not formatted so we cannot install programme to set up dvd writer
go into add/remove programs and look for a previous version of nero. delete / remove it including incd...incd is used for cdrw and dvdrw discs. this is why you are getting format the disc. you will need to reinstall nero again, incl. incd.... also install power dvd it should be on the same disc..
Nov 23, 2009 | Computers & Internet
Invalid book address
this is to do with settings in Nero.
The book-Type is settings For CD/DVD et,c.
The actual Format the disk has to be written in. If you,ve got the book-type set to write a CD for example, and burned a DVD. it would error as it needs to write more data, than the Disk Allows.
CD 650mb. DVD 4370 mb or equivalent.
I,d uninstall-re-install nero, and ensure you select your type of disk to Compile. Which will automatically select The Correct Book-Type for The compilation required.
Mike @ Compurepair.
Oct 22, 2009 | Computers & Internet
Nec DVD writer. Does not load disc, although it is is trying to. Nero copies and burns DVDs but 1Click, clone DVD, Fab programmes won't. Any ideas?
Used to run into this all of the time.
  1. Nero and Roxio are famous for this. Writers have their own set of drivers that different burning programs hook into to transfer the data onto the disk. It's a hierarchical structure, and quite often a new installation of software takes over those hooks for itself, leaving a disconnect for the other programs.
  • I bet that you either installed or updated Nero most recently.
For the disc that won't load. Is it just one or all? If a disc gets damaged in the base volume files, this can easily happen.
May 30, 2009 | LaCie d2 DVD-RW Burner
HP external 1040 dvd writer
The Nero software came with InCD, which is a program that allows you to drag files directly onto the CD without having to run CD burning software. It's a novel idea, but I don't think it works all that well. If you're not planning to use it, then uninstall it. If you can't find it in the "Add/Remove programs" list, then you may have to uninstall the Nero software and then reinstall it but unselect to have the InCD software installed.
Jan 05, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Serial number for nero 7
i downloaded the nero 8 trail version from the net but it needs a serial key to activate please send me the serial key for the activation and aslo tell me how can i crack it to make it full version
Apr 28, 2008 | LG GMA-4020B Super-Multi...
Nero OEM suite 3, Bundled with my DVD rewriter/burner
you really need to re-install Nero, as you backed up in the format nero uses, its only unpackable via nero.
re-install nero, and this should allow you to regain access to your backed up DVDs.
Mike @ compurepair.
p.s if you search the web hard enough, you,ll get a trial or earlier version Free.
Feb 24, 2008 | Ahead Software AHEAD NERO 6.0 SUITE 3...
Software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
Sep 16, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
