Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer CE-350 bobbin thread tangled now grinding noise
Purchased new 3 weeks ago, bobbin thread case area tangled while in embroidery mode. Cleared all and oiled machine, now grinding noise in embroidery mode. Also flashes E4 code which is "Machine is locked up due to thread entangled with bobbin case or rotation ubterrupted forcibly" I have removed bobbin case again and made sure all dust has been removed, but the noise is concerning me. Holiday Projects I am currently working on are on hold for now.
  • carolcuffman Dec 13, 2008
    Thank you for the advice, what about the grinding noise?
    Thank you for the feedback
    Master:
  • 479 Answers
Its advisable to replace the machine or call the service person at your place to make it proper as the machine is in warranty and this problem is included in warranty so dont worry.and dont try any thing else as if any thing goes broken/or physically damaged   you many loose warranty.
Posted on Dec 13, 2008
    Sergeant:
  • 237 Answers
Make sure the thread is looped through and pulled back. And then, make sure the thread is looped around the machine, along with the tension. This problem usually occurs due to lack of tension.
    Master:
  • 623 Answers
Make sure both top and bottom threads are pulled toward back of machne and under foot before sewing. If the bobbin thread isn't visible to side of material, and if it gets underneath as you start to sew it will tangle it will make a birds nest. Helps if you hold both threads very lightly to side
as you make first few stiches, then let go. Good luck.
  • 19,396 Answers
If you purchased the machine three weeks ago, find a way to have your money refunded, this is a repair that must be done by a technician and will cost money.
  • Ginko
    Ginko Dec 13, 2008
    Contact Singer, it is also possible that the machine was defective from factory, if it has failed this soon. They will tell you what to do, or put in touch with technical support.
    1-800-4-SINGER
    Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
Singer futura quartet embroidery machine's bobbin area is tangling up the top thread. the top thread never breaks it just clogs up in the bobbin compartment can you help?
Be sure that when you thread the top thread, ALWAYS RAISE the presser foot. This allows the thread to seat firmly in the tension disk. Sounds like what you are experiencing is called bird nesting or thread nesting.
Jul 11, 2017 | Singer Sewing Machines
E4 message
contact singer customer service about the error code e4, the resistance could be a broken or damaged part.
Mar 22, 2014 | Singer Sewing Machines
Stitch
Mine is doing the same thing. It's pulling the thread up from the bobbin and making a huge knot. Any suggestions. I've done all the above checks. Brand new needle, tension is on embroidery, threaded properly and no lint in bobbin compartment.
Jul 28, 2010 | Singer CE-200 Quantum Futura Computerized...
I am getting birdnests under the strikeplate under the needle
try flipping the bobbin and bring thread up manual and bring thread to the front long enough to 7-8"
Sep 05, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-100(Singer)
Sounds like a tension problem. Email the singer company at talktous@singerco.com They should be able to help!
They responded back to me the same day.
Nov 17, 2008 | Singer CE-100 Futura Computerized Sewing...
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
148 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
