Question about Dell E171FPb 17" Flat Panel LCD Monitor
Padlock appears on screen
I was out of town for 6 weeks and when I returned, my Dell e171fpb monitor now has a padlock that appears on the center of the screen. I tried to access the OSD menu, but none of the buttons on the front of the monitor work, other than the power button - any suggestions? I've unplugged it, held in the menu button for 15 seconds and I also tried changing the resolution setting from the control panel (these were suggestions that I found on the dell web site) but they did nothing. Thanks!
  • 2 more comments
  • Kathy Grifaldi Mar 17, 2007
    Once the padlock is "un-locked" and I let go of the menu button, the "locked" padlock returns. Any other suggestions?
  • amorganti May 02, 2008
    I have exactly the same problem! One morning everything was fine, then in the afternoon the padlock had appeared. A friend has given me a suggestion of something to try and I'll let you know if it works.
  • Anonymous May 08, 2008
    I have the same problem on my Dell LCD monitor. After the padlock pops up the screen menu will also pop up without touching any buttons. Very annoying!!
  • marysiab536 Mar 19, 2009
    i have a dell computor which has a flashing bluish square with a padlock in it so annoing help
    Champion:
  • 217 Answers
Hold the menu button until the padlock unlocks, it takes anywhere from 30 seconds or even a minute or so
Posted on Mar 17, 2007
  • 3 Answers
I simply unplugged the screen from the PC (NOT the power cord), waited a minute, then reconnected it. Hey Presto the blue thingy was gone and I could fully use the adjustment buttons.
Posted on Sep 12, 2009
Go to OSD settings and see if the padlock is locked or unlocked, click on no
Posted on Apr 03, 2008
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck.
Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor.
http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display):
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
Jul 07, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 29, 2012 | Computers & Internet
I keep showing a padlock when i try to adjust my E172FPt monitor brightness
Press and hold the menu button for 15 seconds or until the locked padlock icon changes to an unlock padlock. When it becomes unlocked, you can adjust your monitor. Hope this helps you.
Jan 28, 2011 | Dell Computers & Internet
I have a blinking padlock in the middle of my monitor screen. What's wrong?
I'm not sure of the exact cause of this issue but I've heard of similar problems being caused by your desktop resolution being out of sync with the resolution of your monitor.
I've read elsewhere that the problem has been fixed by Right clicking on your desktop, going to Properties & adjusting your screen resolution to something different, clicking apply...then adjusting it back to whatever you'd like.
Failing that, I'd suggest giving Dell customer support a call. They have access to a lot more diagnostic material including button combinations that may clear the error out.
You can log a ticket online with them, or call them directly. The number can be found on www.dell.com
Nov 20, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
The padlock is an indication that the On Screen Display is locked. You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds.
http://support.dell.com/support/edocs/monitors/e171fp/en/controls.htm
Sep 30, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
I have this monitor,got it used at the goodwill, padlock problem and the control buttons (eccept for power) did not work. I tried every solution posted with no success. Then I got brave, I dove into the problem. 1) remove base, four phillips head screws. 2) remove the back, five phillips head screws. one in each corner and one behind the base mount, thus the need to remove the base. 3) carefully pry off the back, it snaps on, so take your time. I found a butter knife to be very helpfull. 4) The buttons are sodered to an electrical board whitch is snapped into place so carefully pry up from one side,again I used a butter knife. The wires are sodered to the board, they do not unplug. 5) Using a can of air, blow into each button and trying to clean out the inside them. I'm sure they should probably be replaced but we do what we can. 6) Put it all back together. 7) plug it in and connect it to computer. start working the buttons, at first I thought it was a lost cause but after about a minute I was able to get into the menue, scroll down using the arrow buttons and turn the lock off. A $300 monitor for 40 bucks. I hope this message gets to you before you give up. GOOD LUCK, GMAN8773
Sep 05, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Flashing padlock icon in the middle of the screen
When the icon is in the unlock position, hold down the Menu key (the far left button in the lower righht hand corner) on your monitor. This should bring up the menu. From there, you can reset the factory settings.
Mar 16, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb 17" Flat Panel LCD Monitor Logo
1,643 people viewed this question
Clive
Clive
Alun Cox
