Question about Samsung HL-S5687W 56" HDTV
TV has dark streak on one side of screen.
Picture can be seen behind the dark streak. Dark streak appears to be getting larger with age.
  • 106 Answers
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Posted on Dec 13, 2008
I can see my picture, but it has gone dark. I replaced the bulb and the picture has not improved. Any idea what else could be wrong. This is a samsung hls5687w model
Posted on Feb 12, 2009
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Can't get picture screen clean
    If the dark streak is static, then is liquid in lcd panel.
    Oct 24, 2008 | Polaroid Televison & Video
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    Dark streak haqs appeared on screen why
    This can be either the Logic board or your LCD panel is defective. Best to have it diagnosed by a service co.
    Apr 23, 2009 | Protron PLTV-32 Television
    Dark vertical lines on tv screen
    looks like lcd panel is off.the cost is abit less of anew tv!
    Jul 07, 2008 | Televison & Video
    Dark Picture
    Symptom: NO PICTURE
    Cause: DEFECTIVE 3D/YC COMB FILTER
    Symptom: DARK PICTURE
    Cause: DEFECTIVE C724
    Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
    WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
    you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
    Oct 21, 2007 | Mitsubishi WS-55807 TV
    Left side of television just started having a shadowing problem?
    I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
    Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
    Ghostly vertical lines
    you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
    May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
    Brightness and volume
    The dark picture is a bad capacitor for the screen or drive voltage for the picture tube driver transistors. The other problem of streaking is one of the same. Thats the indication that a capacitors defective . It could in a rare cas ebe a defective or gassy crt as well but 99% of the time when a crt is said to be gassy its nothing more then poor drive to the crt. Good luck
    Jun 13, 2006 | Mitsubishi CS-40507 40" TV
    Samsung HL-S5687W 56" HDTV Logo
    456 people viewed this question
    Henry  Thomas
    Henry Thomas
