I have a Lexmark 3400 saying cover open. I've check several web sites and found explainations that seem much too involved. At this point, I'd like to give it a try rather than buying a new printer/scanner.
  • 1,031 Answers
This happens if the lever arm of cover sensor has fallen off'. if you take the scanner part off the top, and the grayish plastic bit unscrewed and popped off, there is a white nylon lever arm that should be seen sticking up thru a rectangular hole...roughly about 1/2" to the right of the printhead behind it. This lever arm clips onto a microswitch/sensor (the lid switch).you can pop the white nylon bit back on and press to fix, .
This sensor is mounted on the circuit board about midway across, and you can see it if you look straight down, through the hole in the black plastic shrouding that covers the circuit board.
It might be possible to snap the part back on without partial disassembly, or simply shove something in there to hold the sensor in the 'closed' possition .hope this helps?thanks and Godbless
Posted on Dec 13, 2008
I have lexmark x3430 all in one printer need to down-load manual
Hope you already got a copy of the manual. If not, here's the link to download the User's Guide for Lexmark 3400 Series printer. http://www.lexmark.com/publications/pdfs/3400/eng/ug.pdf . Hope this helps.
May 09, 2010 | Lexmark X2500 All-In-One Printer
Lexmark 3400 printer display says cover is open. Cover is not open. apparently it is mis reading status. will not print or turn off. Its stuck. What do I do? D.S.T
do a hard shut down..unplug power cord...that would make it go off. them leave it off for 2-3 minutes..then turn it back on and let me know the status
Jun 05, 2008 | Office Equipment & Supplies
Series 3400 printer
If your printer still in warranty please replace the printer or This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located..
Good luck....
Oct 30, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 3400
im looking for the software to run 3400 can you help me get it
Jul 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
All in one Lexmark 3400 will not scan
put in new ink cartridge, printer states cover open. re checked cover and cartridge dozens of times. still says 'cover open'
Jun 04, 2008 | Office Equipment & Supplies
LEXMARK 3400 ALL IN ONE
I have a lexmark 3400 and it will not scan for what am i doing wrong??
Feb 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark-3400 install trouble.
Try installing the disc as Administrator account as opposed to a generic user account.
Most problems with Vista stem from the strict protocol of not being able to modify windows in any way, unless logged on as Admin.
This may also be the case for several other applications or programs as well.
Jan 09, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmar 1270 will not install
seem's today there web site is down
http://techsupportforum.com/hardware-support/printer-support/124008-lexmark-1270-install-problems.html
riz.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
jasbo
jasbo
