Question about Samsung HP-R5072 50 in. Plasma HDTV
Flickering picture and color lines
I have had my tv for about 1 week now, and I just had a problem today. I was watching tv on it earlier. I shut it off, came back to watch about 3 hous later and now there is a very grey flickering occuring, and there are color lines in Green and Red situated across the screen. I tried it in allt he sources and it does the exact same thing...What can I do to fix it, or am I goin to have to make a warranty call? GrimmJitsu
    Sergeant:
  • 308 Answers
You didn't mention what equipment you have hooked into the set, Cable Box, Satellite, DVD., etc. So I would try using a different component or different cables to make sure it is not an intermittent connection either in some of the cables or an external signal source. Otherwise a warranty call may be justified.
Posted on Mar 12, 2007
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Jun 28, 2008 | iLO LCT32HA36 Television
Why does picture have lines of different colors?
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Have thin line of picture on right side of screen, rest is blank. Sound is fine
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | LG 32LG30 32 in. LCD HDTV
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
188 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
