Click start control panel view devices and printers you should see your web cam from there image devices you could see a yellow question mark ? right click to reinstall drivers or update driver
if you are have trouble with your web cam
click start control panel administrative tools ,computer management ,device manager scroll down
this will vary depending on your operating system
http://download.cnet.com/chicony-usb-2-0/3000-2110_4-180132.html
hope this helps
SOURCE: Chicony USB 2.0 Camera: NEED HELP!!!!!
I think its a common problem to toshiba notebook try to do step serious from this link
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1730705&moid=1702269&rpn=PSPB0U&BV_SessionID=@@@@0743031691.1188984163@@@@&BV_EngineID=cccjaddlliekmghcgfkceghdgngdgnj.0&ct=SB&all_docs=false
takecare.
SOURCE: Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
SOURCE: Can't Acess My Chicony U.S.B Webcam, no icon, ALWAYS WORKED
try to start the interface of webcam using :
1. start menu > programs > chicony webcam
2. open C: drive > program files > chicony webcam and double-click "chicony.exe" file
3. in the properties, check "show in task bar"
SOURCE: my chicony USB 2 camera is not working on my
This is a common problem on laptops. It generally means
the webcam or the webcam cable is faulty and needs to be replaced. The only way
to tell which is faulty is to try one, and in rare cases both may be faulty.
Before you try replacing the webcam you could try updating the driver,
to do this you need to goto the manufacturers
website, find their support section and there should be a list of drivers for
your specific machine. I have a list of links to most manufacturers drivers on
my website.
If the driver update fails then look on
ebay for a webcam and cable for your laptop. Installing can be tricky as you
need to remove your LCD bezel and laptop top cover as the webcam connects to
the system board.
Hope this helps,
www.PuterCare.com
