Question about Honeywell Programmable Thermostat Heater
Honeywell RTH3100C I have on old White-Rodgers 4 wire single transformer system I believe. Model 1F76W357. I am installing a Honeywell RTH3100C non programmable thermostat. Wires on the White-Rodgers are: RC RH (Jumpered inside the thermostat) W Y G Wires on the Honneywell are: E AUX Y G O L R B C I tried to hook it up like this: RC/RH = R on the Honeywell (RC and RH are 1 wire out of wall) W = AUX on the Honeywell Y = Y on the Honeywell G = G on the Honeywell When I turned the heater, after 3 minuts the AC Kicked on. Online, I have learned that on the old White Rogers these wire are: Y=Cooling System G=Fan Relay W=Heating System RC/RH=24v Hot So I tried a couple of other combos and no luck, I just cant figure out the whole RC/RH thing. Please let me know if there is an expect that can help. KMC
  • 407 Answers
You are on the right track, however, the biggest problem I see is that the new Honeywell thermostat that you have is for a heat pump system and judging off your old thermostat, you don't have a heat pump. A heat pump system requires more wires and different terminals for the extra components it has like the reversing valve and such and since you don't have any of those, your thermostat is trying to tell the old unit to do things it simply cannot do. Your wire colors are correct as you described and on a standard thermostat you will have the same terminals as you do now. C/B(Blue)= is common by the way. One way to look at the RC/RH terminals is to think of it as both 24v, one being for heat(H), and one for cool(C). When they are jumped together, it allows the thermostat to use one wire for power instead of two (Red). Hope this helps and good luck!
Posted on Jul 14, 2010
  • 99 Answers
RC - power for cooling
RH - power for heat
since you have only one transformer you need to put a jumper with this two terminals.
RC/RH - R ( power )
G - G ( fan relay)
W - Aux ( heat relay)
Y - Y ( cool relay )
this is so simple if the Honeywell thermostat is doing erratic operation maybe you need to reset the thermostat.
Posted on Sep 15, 2009
  • Joselito Laxamana
    Joselito Laxamana Apr 07, 2010
    The main reason why the RC/RH terminal has a jumper in between. IF you are using a single transformer you must used a jumper to power the RC (power for cool) and RH (power for heat).
    I think you need to call Honeywell so that they can help you with the problem, you know the function of each wires so this will be a piece of cake for them. Here's their number 18004681502
    Link:https://yourhome.honeywell.com/home/Appl...
  • Joselito Laxamana
    Joselito Laxamana Apr 26, 2010
    RH - power for heat
    two terminals.
    RC/RH - R ( power )
    G - G ( fan relay)
  • 478 Answers
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Posted on Mar 12, 2009
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Installing a Honeywell TB8220U programmable thermostat. All of the wires are connected but AC will not come on. I believe I have a single-transformer system. I have the red wire connected to ''C'', since...
On the old thermostat how many and what terminals did you have?
Usually
R = Red One Side of 24 volt Transformer
RH = Usually jumpered to R or RC
C = Common the other side of the 24 volt transformer opposite the R
G = Green Blower
Y = Yellow Cool
W = White Heat
May 30, 2010 | Honeywell Electronic Programmable...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
I bought new Honeywell non programmable,letters are different.
If you have a 5 wire thermostat then you have a two transformer system a cooling transformer and a heating transformer.
The cooling transformer wires to Rc - Y - G,
and the heating transformer wires to R - W the R terminal heating would be the #4 terminal from the old stat.
Aug 12, 2009 | Honeywell Electronic Programmable...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,057 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
