Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Hot wayer when turned to cold
When you turn on the cold side hot water justed started coming out i think it must be an adjustment
  • 1 more comment
  • mactrucker52 Dec 14, 2008
    it has been working fine until now.over a year later.
    it is single handle
  • Roscoe007 May 11, 2010
    Is this a single handle ,or two handle faucet ..Are other faucets , working ok?
    Did this just happen after new faucet was in stalled ,or has faucet been working fine up until this point?
  • 101 Answers
  1. Sounds like a diverter problem .. you will need to,shut the water off take the faucet handle off ,then you will see 1 screw that hold down the cap to the diverter, after this is removed you will be able to remove and the diverter.Lots of times they just need to be reseated.
Posted on Dec 15, 2008
What does mean wayer coming from tailpipe 2000 Silverado
During combustion many gasses are produced as well as particulates. Water vapor (think super fine steam) is also produced and depending on the temperature outside and/or the temperature of the exhaust system (e.g. when first started it would be cool) the water vapor condenses and drips from the tail pipe. Just like water drips from an ice cold beverage container on a hot, humid day. ;-)
Nov 27, 2015 | Cars & Trucks
No hot water
Check two things, 1- check that the hot water heater bypass valve is completely closed so that it is not bypassing at all and mixing cold water . 2- check your outside shower valves, make sure both of those are turned off...if they are turned on but the valve on the head is turned off...this will also allow cold water to mix in the hot water line. If those check out ok...then the mixing valve is likely clogged, you could take it off and try soaking it in boiling white vinegar, or try to adjust it, there is an adjustment screw under the black cap, I think its an allen screw...but they fill the center with glue so you can't adjust it...you have to dig that glue out so you can get the allen wrench in...may even be a torx screw...either way it can be adjusted, you just have to dig the glue out first.
Apr 09, 2014 | Atwood Mixing Valve 90029
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
The faucet I am having trouble with is a single lever, kithen faucet. It is a Moen PureTouch faucet with water filter in wand. The cold water works fine no matter what on either cold side or hot when the...
This needs a new cartridge and may only cost you a couple of bucks at your local plumbing store. If you do this yourself, just make sure you turn off the water to both the cold and the hot and you will probably just need a allen wrench, screw driver and maybe a cresent wrench.
Aug 03, 2009 | Moen Plumbing
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Scalding hot water from cold tap for short while, then cold.
sounds like you have a hot water leak un der your foundation.
Jun 16, 2009 | Water Heaters
Problem with hot water flowing from cold outlet
The hot and cold pipes run in the wall next to one another. So the water turns cold again as soon as the water starts flowing
Jun 16, 2009 | Honeywell Water Heaters
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
Cold water tap not working, house heating not as strong.
Okay let's trouble shoot this problem. The Hot water issue may just be that your Temp. control is not set as high as it was before it was replaced. Find the control on the water heater and check the setting. You can adjust it hotter from there, but it is not recomended to set it all the way to HOT. Just increase it at small adjustments and see if the water gets hotter. The Cold Water Tap issue.....Turn off the Cold and Hot water supply lines to the faucet. Remove the Cold water tap. VERY SLOWLY TURN ON THE COLD WATER SUPPLY and see if you get water coming out of the line. If you get water, then your line is okay. Inspect the valve to see if there is any debris in or on it. Clean and reinstall both taps and turn back on the water. It should work. Now if you turn the water on SLOWLY when the Cold water tap is removed, and no water comes out, Then you know you have an issue with the line going to the cold water side. (Frozen Line, Debris in supply line valve, Broken or Leaking Water Line) I hope this assists you........Joe
Jan 16, 2009 | Plumbing
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
116 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
