Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
Sceptre X76NAGA VI Monitor
Have had this monitor only a few months- maybe 4 or 5 and never any problems but all of a sudden the screen turned yellowish while I was just reading email. I hadn't done anything -just reading- and then later on the screen turned back to the normal white. went to the resolution and color area of control panel and tried different settings but it didn't make any difference. Could this mean my video card is going out? My previous monitor didn't have the yellow problem it just died of old age. Thanks in advance for any help you can offer.
  • 624 Answers
Ksto, It could be a bad connection somewhere. Try checking: -Where the video cable plugs into the PC. Remove and check for bent pins, corrosion and replace and firmly reconnect using the thumbscrews on the connector. -Where the video cable plugs into the monitor. Some LCD monitors have removable cables some don?t; if yours does follow the same procedure outlined above. -If your video card is not part of your motherboard it could be the video card not being seated properly. Remove it and reinsert the card. -If still nothing I would try entering the monitor configuration menu (using the buttons on the monitor) and reset it to factory settings. -Next step would be connecting your monitor to another PC to see if the problem follows it. If it does I would immediately contact the manufacturer for a warranty replacement making sure you read your list of what you?re already tried. -If the problem doesn?t follow the monitor then that points to your video card. If that?s the case let us know what you?ve found out and we?ll go from there. Good luck and please don?t forget to rate this post.
Posted on Mar 14, 2007
X7 G-NAGA VI POWER SUPPLY Transistors
do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Jun 04, 2010 | Sceptre 17" LCD Monitor
Same problem here
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Oct 04, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre 17
It's these cheap power inverters! They blow out in 3 months.
Nov 18, 2008 | Sceptre 17" LCD Monitor
Sceptre X9G Komodo IV 19 in
check out any dry solder or burnt and re solder it , hope it helps AJ
May 03, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor Problem
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Jan 17, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre DCLCD19+ MONITOR WHITE SCREEN
To me it sounds like the bulb is having a problem with powering up. It may be an issue with the power adaptor or the outlet it is plugged into. Have you tried to plug it in, in other outlets?
Dec 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Screen goes blank
Yes, its not the bulbs, its the inverters that are build right into the power module and all that is wrong with that is one or more bad capacitors (bulging or burst) so don't waste $100 getting a new module from Sceptre, fix it yourself (if you have the skills and tools - which wasn't much - a new cap, some flux core solder, and iron, maybe some desoldering braid and then basically a little desoldering and then resoldering). I got lucky and only had to replace one 330uF 16V cap that was bulging and mine is all fixed. For more specifics check under the Sceptre 19" monitors where some very detailed repair procedures are posted.
Aug 22, 2007 | Sceptre 17" LCD Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
