Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
Sceptre 17" monitor X7G-NAGA VI
Monitor is only a few months new (my previous monitor died) - and had no problems until now - I will be using computer and suddenly the screen turns a yellowish tint - the entire screen and later on it will go back to normal white - I've made no changes or updates recently to attribute to the change and don't know whether it is the monitor or my computer (video card?) causing the yellow tinted monitor screen. Anyone have any suggestions on what it could be?
3 Suggested Answers
GordoXX
  • 3 Answers
SOURCE: Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Posted on Sep 13, 2009
SOURCE: X7 G-NAGA VI POWER SUPPLY Transistors
do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Posted on Jun 06, 2010
Testimonial: "I will search ebay, and maybe that´s the best way to find that components,Thank you!"
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Jun 04, 2010 | Sceptre 17" LCD Monitor
Cannot use the 5 push-bars on X7G-NagaV to reduce the pink (red in) the background. Do you have instructions for which button to push & the sequence? Thanks
Please check to make sure that the pins on both ends of the VGA cable are OK and seted properly on bothe ends.
There is no adjustment for color casting on the screen (redish, greenish, or bluish cast).
You may have problem in the monitor or the video card.
http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 09, 2010 | Sceptre X7G-Naga 17" LCD Monitor
X7G shows video for 1 second then goes black, any replacement boards available?
Hate to tell you that replacing parts on a monitor would be very hard not only to find the parts but it would be very costly, I would recommend scrapping it and buy a 90$ refab off tiger direct or something, the only thing you can really fix on a monitor is perhaps a dead pixel, other than that its not worth it.
Mar 21, 2010 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre X7G Naga VI dissaembly.
I have a bad power supply in mine as well. trick to opening it was popping off the silver caps on the base to remove the base. then using 2 bladed screwdrivers carefully pry the front plastic bezel off the back. there is no glue just locking tabs.
Dec 04, 2009 | Sceptre 17" LCD Monitor
Sceptre X7G-Naga VI
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Monitor turned black
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Nov 03, 2007 | Sceptre 17" LCD Monitor
Sceptre 17" Naga monitor
try another monitor on your pc. I suspect bad video source.
Jun 09, 2007 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
49 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
