Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Help with my tv
Light flashes 9 times and wont come on what do i need to do
  • Anonymous Dec 29, 2008
    light flashes 9 times and wont come on what do i need to do
  • Anonymous Dec 31, 2008
    mine has been like this for 2 weeks.. my brother-in-law thinks it might be the light bulb, but he dosen't know for sure..
  • Sony Master
  • 5,138 Answers
Replace D6301. CK D6116 D6117.
Posted on Jan 01, 2009
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
Tv wont turn on
Your lamp need to be check or replace it.
Jul 24, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a Rogers HD cable box and want to control my Soyo HDTV with it. I look in the Rogers manual but could not locate the device code. Can you tell me what it might be?
first you have to know witch remote you have there is a 3 button witch has vcr tv and cbl at the top that one there press tv and select at the same time untill the light flashes 3 times release then enter 9-9-1 the pres the tv button untill the tv turns off if you have the newest 5 button remote you will press tv release press and hold setup untill light flash's 3 times then enter 9-9-1 light will flash once entered then press ch+ sevral times untill your tv turns off once tv turns off stop and press setup and that will lock the code inplace i hope that helps
Nov 24, 2008 | Soyo DYLT032D 32 in. LCD Television
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Projection tv wont turn on
i had same problem after house power switched off 3 times in same day disconnected power left overnight worked ok i will still take tv for a service .
red light was blinking 10 times
Sep 27, 2007 | Televison & Video
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
