Question about Epson Stylus CX5400 All-In-One InkJet Printer
Printer my epson printer is not printing, yes i have ink just changed all the inks all full, ran a head cleaning everything moves and makes all the correct nosies but the paper is blank. help
  • 1 more comment
  • Anonymous Mar 14, 2014
    the printer does not print text. Blank paper
  • Anonymous Mar 21, 2014
    ink head will not move, will not print.
  • Anonymous Mar 28, 2014
    ink spills on paper while printing
  • 328 Answers
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
I had a Hp deskjet that it didn't print but made the sounds. Come to find hp solution software wasn't seeing the computer online. I had to tell hp I was going to trash it.A day or 2 later to printed with a brief message from hp I barely caught it. sor1946@yahoo.com
Posted on Sep 01, 2007
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
My black ink cartridge ran out and it was 2 weeks before I replaced it-the old cartridge was still in the printer. Now with all new cartridges it will not print solid black-only a grey color instead of...
Hi Good day!!! if you try the head cleaning for 1 dozen of time and nothing has change, try this one method I'll give you, before you buy a new printer. all you need to have is a cleaning solution kit and a syringe.
1. remove the cartridge to expose the nozzle that feed the head
2. fill syringe with 2ml of your cleaning solution.
3. push end of tube over the nozzle that takes ink from the cartridge.
4.gently push the syringe allowing 1ml of cleaning solution to pass down the tube and into the head
5. leave the syringe in this position for couple of hours to allow the fluid to soak the dried ink particles.
6. after a couple of hours gentle push the rest of the fluid through the end
7. the next few prints may be contaminated with cleaning fluid and you are advised before carrying out any prints to do a full head clean using printer utility.
8. if after step 8 you still have a problem you can repeat the operation up to step 6, but instead of pushing the fluid through the head draw the fluid back into the syringe, and then back to the head, this causes fluid to move backward and forward in the head assembly, you should notice air bubbles and very small dried ink particles whist doing this. Please note while this product will remove stubborn dried ink particles it will not damage print head.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
No print
In a confused situation like this, it is very easy for the computer to mis-report the amount of ink left in the cartridges. The reason for this is that the printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly etc. The best way out of this situation is always to start from a known position i.e. that you have a set of full cartridges. So, get a complete new set; save the old ones - you can use them later when you know where you are.
Install a new set properly, such that an ink charging cycle takes place, Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. If not, try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If this fails to work, you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Regarding your old cartridges, buy a chip resetter on e-bay (currently one for sale at £3.25). Reset all your old cartridges to "full". Tape up the outlet nozzles and save the cartridges When cartridge change time comes, use the old cartridges. If they work - fine, use them until the ink disappears, then chuck them away.
Mar 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
C84 not printing
I assume that before the old cartridges ran out of ink, everything was printing normally. If so, the usual reason for this problem after a cartridge change is getting air into the print head system. Did you do a proper cartridge replace process, which finished with an ink charging cycle? Have you tried running 2 or three head cleaning cycles? If not do it, then run a nozzle check. Any sign of ink - yes - then things are OK you've just got to get the ink flowing properly. Run a couple more cleaning cycles then leave it to rest for 24 hours to let the air bubbles disperse. Then try again.
If you get no sign of ink after these processes report back.
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Epson Stylus CX5400 All-In-One InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
