Question about Coleman Powermate Powermate 5000W Generator
Oil for Coleman Powermate 5000 PM0545305.03
TS Fay just made our lights blink off and on. So, I'll go try to buy some oil for the Coleman Powermate 5000 I just got my hands on this afternoon. I have no instruction manual. It is about 3+ years old and may have never been started yet. I'm wondering if a 30 weight oil is correct for this Briggs & Stratton 10 HP motor and what the oil resevoir capacity may be. Also, any suggestions on firing it up for the first time? I simply need the starting instructions for this generator. I bought it 7 years or so ago. I just want to make sure I do it right! Any help! Any manual instructions would be appreciated!
  • 169 Answers
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Posted on Dec 14, 2008
2 Suggested Answers
SOURCE: Oil for Coleman Powermate 5000 PM0545305.03
Engine is loaping. I have changed the gas stc. Still loaping. As engine loaps, the lights dim and small ac window unit will not run property.
Posted on Sep 21, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
I have a coleman maxa 5000 generator no spark
first look at the oil level some generators have a low oil shut off then remove the front cover of the engine and unplug the small wire on the side of the coil then try to start it if you get spark back the its a wire problem if still no spark then the coil is bad
Aug 15, 2012 | Coleman Powermate Powermate 5000W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
Oil requirements for Powermate 5000
10-30W or a SAE30. usualy 600mls 0r 1200mls
Jan 27, 2009 | Coleman Powermate Powermate 5000W...
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Oil
Coleman 018-0060ct air compressor oil or equal
most hardware stores will stock it.
Aug 31, 2008 | Coleman Powermate Premium Plus 6250W...
My answer:
First of all - Almost every 4-stroke Genset engine out there should use a minimum 10-30 or else a 10-40 oil blend tops. Best NEVER to use just a straight weight, as in a 30 or 40 weight, as that would be way too "high viscous" at colder temps and could destroy the engine due to overheating at MAX Genset LOADS!
Next - If the Genset is indeed brand new then you need to use the proper fuel in it, as certain mfr's require different fuel blends (such as with certain B&S - Briggs & Stratton - engines), and those engines are set up that way to run on that blend alone. Using the wrong gas blend could damage the engine.
You really need to get a factory Users Manual for your Genset there and read it through thoroughly!
If it has gas in it now (and hasn't run in 3 years?) chances are the whole gas tank, and fuel lines, and Carb as well will need to be cleaned out from contaminated fuel - as there definitely is gum and varnish built up everywhere in those fuel delivery areas esp the most important component - the Carb! Been there - seen that - cleaned that! So I KNOW for FACT.
As for the OIL LEVEL - that is fairly simple - as all you do is unscrew (or in some cases pull out) the dipstick, and check the oil for proper level on the stick as well as cleanness (2 finger test like with car oil), and if it's even black or a silvery color then it definitely needs to be changed out NOW! Refill with fresh oil and your done there.
Check the Air Cleaner for cleanness as well, and service the filter if a foam element, or replace it if a paper element.
If the fuel tank has an in-line fuel line filter and it looks dirty change it out as well. Esp if the gas tank is made out of metal.
Check the spark plug for proper gap, and heat range, and burn color if the Genset has been run already. Should be a nice "light tan" color. If dark and wet - then you have Carb flooding problems.
That about covers it...
Anything else problem wise feel free to ask me here in post follow-up and I'll be glad to answer it for you.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Aug 20, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
867 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
