Question about HP Officejet 4110 All-In-One InkJet Printer
Hp 4110 prints from computer, but says" scan failure" when you try to use as a printer and the fax tele line if plugged in demos the phone lines
  • 684 Answers
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Brose My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 18, 2009
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
No print outs even after clicking print
click the start then go to printer & fax right click on the hp 4110 then select as default, then try print from your computer again,
Aug 07, 2011 | HP Officejet 4110 All-In-One InkJet...
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
All-in-one 4110 hp fax not working
what kind of connection you are using, I ment broadband or some other
Aug 21, 2009 | HP Officejet 4110 All-In-One InkJet...
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Jun 19, 2009 | HP Officejet 4110 All-In-One InkJet...
HP officejet 4100 series all-in-one Scanner not working
tengo problemas de compactibilidad ente los istaladores de la hp 4110 all-line one con windows vista que hago
Feb 18, 2009 | HP Officejet 4110 All-In-One InkJet...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't manually make copies or manually fax.
hi i need 4110 scan 7copy &printer
sofeware driver pl arrange me
Mar 05, 2008 | HP Officejet 4110 All-In-One InkJet...
HP Officejet 4110 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
