Question about Lexmark X75 All-In-One InkJet Printer
Paper jam how to fix
    Problem Solver:
  • 33 Answers
The same thing happened to me once. Try looking near the cartridges and where you input the paper, there might be an item stuck which makes it hard to print or load the paper. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
If that doesn't solve the problem, try contacting the manufacturer.
Hope this helps!
Posted on Dec 14, 2008
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
Tip
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer: https://youtu.be/4nGBQ0H1RQw
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Lexmark X75 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
