Question about JVC AV-27D302 27" TV
AV 35750 no images only sound with cable, images & sound with DVD
TV will not read the the cable during autoscan.  I have to manually input the channels.  I can hear the stations but I cannot see them, the screen is dark.  The cable works fine because I brought another TV in to test it.  I went through the entire menu and I have no idea what to do next.
Please Help
  • 55 Answers
Make sure the cable is on when you autoscan. If the autoscan doesn't see it,manually inputing won't get you there. Make sure you have the correct band selected when you autoscan.
Posted on Mar 09, 2009
How do i hook up a dvd player yo a 55" emerson flat screen tv
Use a n AV Cable, Yellow (Video) white (Audio) Red (Audio) and plug into DVD AV OUTPUT and plug into TV AV 1 or AV 2 Inputs and then select the AV Input you are using on your TV Via your TV Menu and you shall have sound and Picture.
Happy Movie entertainment.
Jul 31, 2014 | Televison & Video
No sound
sound problem is your input menu or your cables r plugged into wrong ports.push input ,go to s video ,component hdmi,or av 1 or 2
make sure,if your tv hasside av inputs,you plug your coverter box(direct tv etc.) into the side inputs,then use remote
If no power from external inputs,then most likely its an av axial capacitor only it will be grey and look like more like a relay
Oct 03, 2012 | Televison & Video
Will a Funai 31B750 Nicam VCR play analogue tapes on a Samsung UE40D5520 TV and will it record from this TV?
Yes of course if the TV has composite video inputs ( Yellow/White/Red ) sockets at the back. Just connect a 3 RCA to 3 RCA cable from your Funai video out to the TV's AV input. Make sure you don't get the colors mixed up. Select the corresponding AV input on the TV and one should get the VCR image provided the head of the VCR is clean. If not you won't get any picture nor sound.
Sep 26, 2011 | Televison & Video
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
JVC av-35750 digital or analog???
Unfortunately this TV does not have a digital tuner built in.
Is not digital ready.
Jun 28, 2009 | JVC AV-35750 35" TV
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
JVC AV 35750
its a boat anchor dont break jus hvy
Aug 06, 2008 | JVC AV-35750 35" TV
No sound when using coax...
Do you use AV inputs for your Cable box? If so, try swapping the audio inputs in the TV, that is, interchange the AV inputs for your DVD and cable box. If sound is audible in a different input, then the Audio input (for Cable) on your TV is faulty. One simple suggestion, Why don't you route your Cable signal through the Tuner of your VCR?
Aug 08, 2006 | Zenith C19A21D 19" TV
JVC AV-27D302 27" TV Logo
64 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
