Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52W14 power button blinks 3 times
Have RCA D52W14 Tv and noticed the solution is to replace flyback, however I noticed under part numbers that my model shows using flybk 259296 but other solution said to order 250694. Does it or will it make a difference which flybk is used?
Thanks for your time.
  • djoreo Dec 30, 2008
    what are the other two capacitors?
  • sterling1021 Feb 21, 2009
    Called a local repair shop to determine location of 3 capacitors. Obtained caps from UED, replaced and TV works like new. Thanks for your help.
  • RCA Master
  • 5,138 Answers
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Posted on Dec 14, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
Power button blinks 3 times
You need to replace the flyback, and that will fix your set. You can get a replacment flyback at the following link and they will provide free online instant messaging when you do the repair so they can take you through the replacement step by step. You need flyback number 259296 heres the link.
Aug 08, 2008 | RCA D52W19 52" Rear Projection Television
HAVE HD52W59 RCA 52" HD TV . I press power button to turn on the tv and it blinks a couple of times and thats it . Nothing after that . No picture or sound.
If it blinks 3 times when you press power then shuts off you need to replace the flyback. Very easy an inespensive repair/. You can get the replacement flyback for under 50.00 at the following link and they provide free tech support to help you install it by online instant messageing. You need flyback number 259296
Heres the link
Jun 30, 2008 | RCA Televison & Video
RCA D52W14 52" rear projection tv
3 blinks means the flyback needs replacing. very easy repair. You can get a flyback at the following link for under 50.00 with free shipping and free tech support so you can install it yourself. You need flyback 259296 here is the link.
Jun 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
316 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
