Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Brush roller on Hoover upright stops turning
Brand new Hoover upright (Anniversary self-propelled bagged upright--model UH50000). The brush roll stops turning with the slightest resistance. I've taken it apart and ensured that everything is operable as it should be, since the machine is brand new.
The carpet setting is on the highest level. The brush roll bearings are clean and well lubed. The v-belt is the proper model number, and both the v-belt and flat belt are brand new.
    President:
  • 1,673 Answers
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Posted on Dec 29, 2008
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Belt replacement
Your model requires (2) different belts. Here is a link to the belts you need and to the manual:
U6434-900 Brush Roll Belt
U6434-900 Self-Propel Belt
U6434-900 Manual
Nov 25, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Vacuum is not self-propelling and no suction
Replace your rubber belt, it is what powers the self-propel mechanism.
Remove the 4 screws from the baseplate and replace the belt at the rear of the machine.
-R
Sep 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
236 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
