Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
Replacing cartidge in kitchen faucet.
When I line up the holes of the bottom of the cartridge with the holes in the fixture, I don't get equal turning radius for hot and cold. What's up with that? If I turn the cartridge to have equal turning radius, the screw holes don't line up. Can anyone help me?
  • 101 Answers
You wont need to line up with holes... it has a plastic notch in the stem and a grove in the housing,if its a drop in plastic cartridge.
Posted on Dec 14, 2008
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
How to replace hansgrohe M2 cartridge
First you will need to tighten the set screw all the way back in. The use your 4mm hex wrench to turn the screw 4 complete turns counter clockwise. Then remove your hex wrench and the handle should come off. There will be a dome shaped cover with blue and red indicator marks. This will simply pull off the cartridge nut. It is held on by o-ring tension only. Once removed you will see the large hex head of the cartridge retainer nut. Loosen this nut and the nut and cartridge will come out of the faucet. Don't be alarmed if your new cartridge is smaller than your old one. There has been a design change in the cartridge so it will fit smaller bodied faucets but will still replace the older thicker cartidge. If you need any further information feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be glad to help.
Aug 04, 2012 | Hansgrohe Plumbing
I had to replace a small section of the galvanized steel main water line at my house today. In conducting the repair, some small pieces of corrosion material entered the line. After turning the service...
it is more than likely that it is a ceramic insert and they do handle grit , dirt or anything else very well
the fix here will be to remove that ceramic insert and clean out anything that is found
a point of interest here is this
one small section equals all the pipe is in the same condition
you should consider replacing all of the gal pipe with either copper tubing or high pressure plastic pipe
Apr 01, 2017 | Blanco Classic Single Handle Faucet with...
Replace cartridge in Moen kitchen faucet and now
it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
How do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Jan 06, 2009 | American Standard Kitchen Faucet 6310 020...
Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
Dec 19, 2008 | American Standard Kitchen Faucet 6310 020...
Hi folks, seems stupid, but I'm changing the cartridge on my american standard kitchen faucet. If I line up the holes on the botton of the cartridge with the holes in the fixture, I don't have the ability...
Most likely you need to adjust the hot limit safety stop which restricts handle swing to limit the high temp of the water and avoid scalding... check out this link to the install manual for your faucet. Also includes detailed diagram of cartridge alignment just in case you need it.
http://www.americanstandard-us.com/Assets/pdfs/as/install/Install_1859.pdf
Hope this helps, Tripp
Dec 13, 2008 | American Standard Kitchen Faucet 6310 020...
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
174 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
