My computer is a Mac 450Mhz PowerPC G4. For reasons unknown the Lacie 500GB Hard Drive suddemly refused to show up in the Finder or the Desktop. In the System Profiler it appeared as 'Device Unknown'. Can anybody help.
  • rthu Dec 14, 2008
    I am answering Ekse's question. Tomorrow, Monday, 14/12/2008, I will test the device with its power adapter on another computer as you suggested. The device is not very old. It was purchased in October 2007. Thank you for your help.
    Regards,
    rthu
  • rthu Dec 16, 2008
    One of the first things I did was what WIZ suggested, un-connect all the leads, then reconnect. I did not work. I have now taken the device back to the shop to fix it under warranty. Thank you for all the help you gave. One last question: For a really dependable external hard drive, what brand would you advise. Regards. rthu
  • 19,396 Answers
Get a My Book external hard drives.
They are not expensive.
They are fast SATA hard drives.
They have auto power off options to save energy.
They are built directly from Western Digital.
This are the external hard drives I sell more:
Desktop Overview
My Book Essential Edition 2.0 500 GB External ...
Posted on Dec 16, 2008
  • 275 Answers
Try plugging in the hard drive on a different port
Posted on Dec 14, 2008
    Genius:
  • 1,199 Answers
All you have to do is unplug the drive and do a restart this should be a simple way out of that problrm!~
Hope this helps
  • 6,487 Answers
This can be a problem with the connection , if you can also try a different cable that will be better....
    Top Expert:
  • Computers & ... Master
  • 63,456 Answers
Unplug the drive, do a cold restart, this is when the computer is disconnected from the power, wait 3 min's and reconnect and restart, it should recognize th drive, otherwise U have a software issue.
Posted on Dec 13, 2008
    Master:
  • 479 Answers
Check out the connection of harddrive to the machine.remove all the connections and reconnect it will start working.
    Genius:
  • 3,422 Answers
Some LaCie drives now ship with the LaCie Setup Assistant installed.The LaCie Setup Assistant will automatically prepare your LaCie harddrive for use on your system. For instructions on the LaCie SetupAssistant please see our FAQ here. Ifthe LaCie Setup Assistant is not provided on the drive, depending onthe model, your hard drive is formatted Mac Extended (HFS+), WindowsFAT32 or Windows NTFS.
  • If the drive is formatted Mac Extended, you will not need to initialize the drive before use unless you wish to partition it.
  • Ifthe drive is formatted FAT32 it will mount on most Macintosh systems.You will want to keep the drive in the Fat32 format ONLY if you aremoving it between a Mac and a PC. If you plan on only using it on a Macyou will want initialize it.
  • If the drive is formattedNTFS, it will mount on the latest Mac OS, but it will be read-only. Youwill need to initialize the drive before use.
  • To determine whatformat the drive is in launch Apple’s Disk Utility. The Disk Utility islocated in the Utilities Folder in your Applications Folder. Launch theDisk Utility by double-clicking on it. All connected hard drives willbe listed to the left. The mountable partition(s) of each drive willshow beneath it. Highlight the partition of the LaCie drive and look atthe information at the bottom of the window.
    • Priya darshan Dec 13, 2008
      Here is the pic:
      To Initialize or Partition the DriveNOTE: Initializing or partitioning the drive will erase all data on the drive.
      If you wish to re-initialize or partition the drive in OS X, you will use Apple’s Disk Utility.
      NOTE: While various versions of the Disk Utility will be slightly different, they all operate similar to these instructions.
      While
      Apple provides an “Erase” feature, we recommend using Partition to
      initialize the drive, even if you are not setting up partitions. Using
      the Partition utility will verify that all previous formatting
      information is deleted before initializing.
      1. Highlight
        the LaCie drive in the list to the left and click on the Partition Tab.
        (You will not get a Partition Tab if the mountable portion of the drive
        is selected. You must select the drive).
      1. Under “Volume Scheme” click on Current and change to the number of
        partitions you wish to create. If you do not want multiple partitions,
        select “1 Partition”. Do not leave as “Current”.
      2. Highlight each partition to change the Name, Format and Size.
      Select the Volume Format. NOTE: Mac OS Extended will be the best
      format to choose for the external drive. To change the Volume Format,
      click on the chosen format and select another.
      NOTE: If the only format showing is “MS-DOS”, click on
      the Option Button on the bottom of the window and choose the selection
      referring to Apple. (Various versions of OS X will give different
      selections: Apple Scheme, Apple Partition Map, etc.)
      1. Name the partition(s). This is the name that will show up under the drive icon on your desktop.
      2. Check
        the box to “Install Mac OS 9 Disk Driver” if you need to use the drive
        on a computer booted from OS 9. (If you are unsure, check the box).
      3. After making any changes necessary, click on the Partition Button in
        the lower right corner of the window. When the process is complete the
        partition(s) will show under the drive.
      The partition(s) should show on the computer desktop and is now ready to use.
    • 13,433 Answers
    The drive may have a fault, I suggest you try the drive on another computer and see if it functions there, if the drive doesn't function on another computer its very likely faulty of if the drive uses a external power adapter the power adapter may not be providing the drive with enought power to function.
    Hows the warranty on your hard drive how old is it?
    This is just a start report back to me thanks
    Need manual for lacie desktop 500gb hard disk
    http://www.lacie.com/support/index.htm?rid=10033
    Aug 02, 2009 | LaCie Computers & Internet
    Popcorn3
    Not unless that dell is running a Mac OS.
    Popcorn 3 System Requirements
    • Macintosh computer with PowerPC G4, G5, or Intel® processor
    • Mac OS X v10.4.10 or higher
    • 300 MB of free disk space to install
    • Up to 15 GB of temporary free disk space during usage
    • QuickTime 7.1.6 or higher
    Sorry about that!
    Apr 10, 2009 | Dell Dimension XPS PC Desktop
    My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
    You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
    Jan 08, 2009 | Computers & Internet
    How to correct connection problem for two LaCie Desktop Hard Driv
    Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
    Jan 07, 2009 | LaCie Computers & Internet
    Lacie Hard drive not recognized
    If your computer recognized the hard drive before you have installed your last operating sistem(s) that can be the problem. Your operating sistem or BIOS is not seeing your hard drive any more. Installing a new operating sistem is going to solve your problem but try another one, not the operating sistem you used until now.
    Dec 26, 2008 | Computers & Internet
    My lacie Big disk 500GB drive will not mount
    If Lacie does a kind of tickling noise that is the disk head. It means the disk is faulty.
    I will post this on main thread.
    Aug 28, 2008 | Computers & Internet
    Mounting an external hard drive onto my I Mac
    Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
    Sep 03, 2007 | Computers & Internet
    Computers & Internet Logo
    66 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
