Question about Frigidaire PLMV169DC Microwave Oven
Microwave was installed yesterday by "handyman"
The light is on, but no one home... The interior light will not turn off at all. The interior fan will only turn off if the door is open. The clock works, and all other functions except any cook functions. The turntable is not moving when door is closed and light and fan are on. Turntable function set to on Child lock set to Off New wiring and breaker were installed for this. I did plug the microwave (using a heavy duty extension cord) to an existing plug on a different breaker. No change.
  • Frigidaire Master
  • 9,098 Answers
Sounds like you have a defective door switch, door switch mount, or (worse) possible damage to the "hooks" which go into the holes in the chassis to activate the switches. Be sure to unplug it first. If this is an over the range model, you should not have to remove it from the wall to fix it. Generally speaking, you remove the grille across the front, then you'll see a screw holding the control panel frame on. Once that's removed, you lift the control panel assembly up and out. Then you can see the door switches and lathces, etc. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 13, 2007
Ge space saver microwave oven Model number HVM1540SN2SS. Interior fan turns on when door is open. This just started yesterday. Please help
The possible issue may be some door sensor broken or work abnormal. Double check three door sensors, especially for two door sensors who are working on normal close state.
Nov 02, 2015 | GE Microwave Ovens
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
GE microwave fan turns on when door opened
The problem is caused by one or two bad door switches.
Apr 27, 2012 | Microwave Ovens
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Everything appears to work but turntable and light on interior.
It's probably your bottom door switch. See this helpful file.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 04, 2010 | GE JVM1740DM Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
Frigidaire PLMV169DC Microwave Oven Logo
238 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
