Question about Kenmore 63942 Dryer
Whirlpool dryer wont stay hot
How do I take the panel off
  • Kenmore Master
  • 8,220 Answers
Some dryers have a dust cover in back you must remove others simply have a lower panel that is held to the frame with spring clips. A putty knife will work great.
Posted on Dec 18, 2008
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Wont heat up ignites but doesnt stay on
the igniter is probably not hot enough, it needs to glow white hot. if it is orange it needs to be replaced. hope this helps.
Oct 13, 2009 | Whirlpool TGDX640P Dryer
Dryer wont stay hot. it gets cold after first load
If dryer lights for a few minutes and will not stay lit, I believe the solenoid coils will need to be replaced. Click on link below, enter your model number lgr5620kq1 in model search feature and go to the dryer page it shows a breakdown view of your dryer. Also go to common solutions and look for gas dryer problems. I will also be here to help you, Sea Breeze
Mar 21, 2009 | Whirlpool Dryers
Kenmore 63942 Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
